64 in a 60 zone
Discussion in 'Australian Motorcycles' started by Baron Von Rotter, Jun 17, 2004.
  1. Dunno, never bothered to count them.
    Mark.
    Mark Hutchison, Jun 18, 2004
    #81
  2. In aus.motorcycles on Fri, 18 Jun 2004 20:49:41 +1000
    Are you sure?
    My understanding is that it's the leeway the cops are now required to
    give. That is, they book if you are 3kmh over, not 10% over.
    Zebee
    Zebee Johnstone, Jun 18, 2004
    #82
  3. In aus.motorcycles on Fri, 18 Jun 2004 20:49:41 +1000
    Here we go:
    http://www.aic.gov.au/publications/lcj/spot/ch09.pdf
    From July 1990 to June 1991, of 8 545 235 vehicles monitored when
    passing a speed camera, 1 082 122 (12.5 per cent) were detected as
    travelling over the speed limit. On average, these vehicles were
    exceeding the applicable limit by 12.7 per cent. Only in two-thirds of
    the cases (representing 663 095 vehicles) were photographs actually
    taken of the breach. This was because the police were applying a general
    rule that a vehicle had to be travelling at least 10 per cent above the
    applicable limit plus 3 km/h.3 The former is the fairness tolerance
    and the latter is the machine tolerance.
    So yes, you are right in that the 3kmh is the manufacturer thing, Iw as
    confused with the fact the 10% tolerance has been dropped or massively
    reduced so the net effect is a 3kmh leeway.
    I so far can only find 3rd hand accounts of the situation, dur to the
    way google indexes thing....
    Ozbiker had some quotes which imply it's the 10% tolerace that's been
    hit, so the effective tolerance in regulations is 3kmh which is also the
    machine tolerance.
    http://www.ozbiker.org/archived_news/march31/vic_speedcameras_27_03.htm
    "But acting Assistant Commissioner (traffic) Bob Hastings said winding
    back tolerance levels was part of the Arrive Alive campaign to encourage
    people to drive 5km/h slower.
    Mr Hastings said the 3km/h tolerance limit reflected the accuracy of the
    state's speed cameras, laser and radar guns.
    "Cribbing 5km or 10km is no longer acceptable because it causes death
    and injury," he said.
    "As technology becomes better and more sophisticated, equipment becomes
    available even that 3km/h tolerance may need to be reviewed as well."
    Mr Hastings admitted the traditional 10 per cent tolerance had reflected
    Australian design standards for speedometers.
    But he said research showed only a few vehicles had speedometers that
    underestimated speed by more than 3km/h."
    Zebee
    #83
  4. Baron Von Rotter
    Biggus Guest
    But he said research showed only a few vehicles had speedometers that underestimated speed by more than 3km/h."
    Could they honestly believe that bullshit?
    Biggus, Jun 18, 2004
    #84
  5. In aus.motorcycles on Sat, 19 Jun 2004 07:23:33 +1000
    What info do you have otherwise?
    I've had 2 bike speedos that under-read my speed. Out of what, 20
    bikes? And one of those had a non-standard speedo fitted.
    Of the other vehicles I've had, they have over-estimated the speed by
    anything from a bit to a lot.
    Zebee
    #85
  6. Baron Von Rotter
    Theo Bekkers Guest
    You wanted logic? I didn't glean that from the thread. :)
    Theo
    Theo Bekkers, Jun 19, 2004
    #86
  7. Baron Von Rotter
    R1100Smee Guest
    the formula for the cameras is this zebee
    they are set to 7 kmh over the limit
    a vehicle doing 7 kmh over is pinged then the so called 3 kmh tolerance
    is deducted from the speed giving you a 4 kmh over the limit "alleged" speed
    Copper will allow more than 3 kmh in fact for a bike they will use their
    discretion and allow up to 10 -15 kmh over before pinging you
    for a car they will allow 10 kmh over.
    this was divulged by a friend who workks for civic compliance and then
    backed up by a copper we met at the toy run last year.
    There is no % formula used here in vic.
    R1100Smee, Jun 19, 2004
    #87
  8. Baron Von Rotter
    R1100Smee Guest
    This is ausmoto and harsh week
    logic?
    good point:)
    #88
  9. So sorry Nev.
    Or should that be Nev..?
    How many full stops do you need?
    Hammo
    P.S. I'm sure I was well into the second half of the case by then, really
    hope you weren't working!
    Hamish Alker-Jones, Jun 19, 2004
    #89
  10. Not all of it.
    He was a champion with the work I was doing in 96-98.
    Hammo
    #90
  11. You are wrong, then Zebee.
    Hammo
    #91
  12. So you are medico now, or just don¹t follow how disease can be
    multi-factorial and therefore related despite the diagnoses?
    Hammo
    #92
  13. You must have killfilled me cos I sent you three.
    One when it arrived, one when you posted that I didn't reply, and then
    another one with some hilarious visual gags.
    Hammo
    #93
  14. Zebee got it wrong (well, mostly). The ADRs of speedos do apply at certain
    speeds....
    Hammo
    #94
  15. Baron Von Rotter
    John Littler Guest
    Those circumstances being anytime a lawyer considers a judgement in a
    NSW court is persuasive. You can use a decision reached in any of the
    common law countries (ie UK, NZ, US etc*) as argument in a Vic court.
    They are of course not binding on the Vic court, but they will be
    considered. There is plenty of precedent for non binding decisions to be
    accepted as persuasive.
    JL
    *Argument from Napoleonic code countries(France et al) can be considered
    also but it's more tricky apparently)
    John Littler, Jun 19, 2004
    #95
  16. No Smee, that is wrong.
    In 100 zones, it is ten percent.
    Hammo
    #96
  17. Baron Von Rotter
    Moike Guest
    What would Zebee know? She's not a Victorian!
    Moike
    Moike, Jun 19, 2004
    #97
  18. Baron Von Rotter
    Proof that non-Vic Aus.motians don't count!
    Clem
    Knobdoodle, Jun 19, 2004
    #98
  19. Baron Von Rotter
    smack Guest
    the 11 tasmanian ausmotians can't cuont
    smack, Jun 19, 2004
    #99
  20. Baron Von Rotter
    conehead Guest
    Nugget my starfish, you burly oafs!
    He was one of the reasons I turned my back on Victoria. He is a loathsome
    spotted reptile. He threatened my electorate with various plagues for not
    electing his nancy-boy Craig Bildstein.
    conehead, Jun 19, 2004
