64 in a 60 zone
Discussion in 'Australian Motorcycles' started by Baron Von Rotter, Jun 17, 2004.
  1. Cunts have sent me a nasty little letter, 64 in a 60 zone.
    Taking it to court. A clear road, bright sunny day, camera car clearly
    hidden, double laned, wide road.
    Clearly revenue raising.
    Any suggestions on how to approach the beak on this. I dont expect to
    get off it, but I would like to keep the points.
  2. Baron Von Rotter
    Nev.. Guest
    What difference does it make if the camera is hidden or out in the open.
    As pointed out in a thread last week... you're wasting your time, and the
    court's time, and the penalty the magistrate hands you will probably reflect
    that, unless you can produce some evidence that the detected speed is not
    correct.
    Nev..
    '03 ZX12R
    Nev.., Jun 17, 2004
  3. Baron Von Rotter
    Biggus Guest
    Just pay it, they can hit you with court costs and more if they want,
    then you lose out **** loads.
    Biggus, Jun 17, 2004
  4. Baron Von Rotter
    Big Fella Guest
    The Qld Traffic regulations allow for Speedo's to have a 10% inaccuracy.
    That would make your speed fall with in that 10% allowable error range. Not
    sure what the go is in other states.
    Big Fella, Jun 17, 2004
  5. In aus.motorcycles on Fri, 18 Jun 2004 00:49:46 +1000
    Did you break the law?
    IS the law "60kmh or less" or is the law "appropriate speed"?
    So? Did you break the law?
    If it was a camera or other instrument, then your only chance is to show
    or maybe raise enough doubt if you can't completely show, that it was
    being used improperly. As in not as regulations lay down.
    If you can't show that, then cop it sweet. You broke the law. The beak
    doesn't give a shit about whether it was a good law or not, that's not
    their job and they have 58 more bods on the docket after you.
    Your other choice is the old civil disobedience thing, go to court, say
    your piece, refuse to pay the fine, and take the consequences of *that*.
    If enough people are willing to lose money, and time, and maybe
    licences, and go to jail instead of paying up, it becomes unworkable and
    embarassing.
    They are banking on the general reluctance of the driving population to
    be that annoyed about it.
    One or two who protest can be handled.
    In Vic, the 3km leeway means that either lots of people get pissed off
    and protest, which doesn't seem to have happened, or everyone substracts
    5 or even 10 from the number on the sign and pretends that is the limit.
    Zebee
    Zebee Johnstone, Jun 17, 2004
  6. It is probably not worthwhile but........
    I believe that the ADR for speedo's is a 10% tolerance. That essentially
    gives you +/- 6k at 60k
    Essentially then you are using a legal speedo to maintain your speed
    within that speedo's tolerances.
    May be worth trying the 'I did all I could to obey the law' defense....
    Stan.
    Stan Gifford - APAC command centre manager, Jun 17, 2004
  7. Seeing as no one else has posted anything other than "Just cop it sweet" I
    thought I'd post something different.
    NRMA in NSW was looking a while ago at the legality of any speed fines for
    <10% over the limit, due to the ADR for speedos being an accuracy within
    10%. You could do some googling, phoning, etc etc to found out if there is
    anything useful in it.
    James Mayfield, Jun 17, 2004
  8. Baron Von Rotter
    Deevo Guest
    Did you do it?
    All of which is essentially irrelevant if you did it.
    Which, unfortunately, isn't illegal.
    Don't waste your time. Legal types, both Judges and Lawyers, tend to get
    pissed off at frivolous cases and if you piss off the judge you may cop more
    costs.
    Deevo
    Geraldton
    WA, The Nanny State (® Corks)
    http://members.westnet.com.au/mckenzie
    Deevo, Jun 17, 2004
  9. In aus.motorcycles on Fri, 18 Jun 2004 08:25:46 +1000
    The difficulty is that BVR's in Vic.
    It's now *law* there, or at least regulation, that the leeway is 3km/h.
    You are required to know your speed. How you do it is your problem.
    That the ADR has a 10% leeway isn't going to change that, what it means
    is that if you know it could read 10% fast you have to travel 10% under
    the limit.
    Remember that the speed limit is not a *minimum*. You are not required
    to travel at it, you are required to be sure you don't exceed it.
    Zebee
    Zebee Johnstone, Jun 18, 2004
  10. Baron Von Rotter
    While I was heading down to see the guys at Superbikes I was pinged
    for 105 in a 100 zone (aboard Minx's bike).
    I'd suggest moving out of Victoria, the coppers and guvmint are weird
    down there.
    BT Humble, Jun 18, 2004
  11. Baron Von Rotter
    Black Bart Guest
    They have have lotsa cool laws now in Vic.
    A quite popular one is when it was found that pretty much all the fixed cameras on
    the western ring road were fucked and reading faster speeds, they worked out how much
    they had to pay back to busted motorists, said **** that, and passed a law that says they
    don't have to pay it back. And this was after they said they would.
    So even if you did fight a ticket in Vic, and proved the camera was fucked, they still keep
    your cash.
    Black Bart, Jun 18, 2004
  12. Baron Von Rotter
    R1100Smee Guest
    You only lose one point
    is it worth all the aggro?
    R1100Smee, Jun 18, 2004
  13. Baron Von Rotter
    R1100Smee Guest
    this is a victorian matter
    Here its 7 kmh -3
    the cameras are calibrated to 67 kmh then 3 kmh deduction hence the 64kmh.
    don't believe the + or- bullshit.
  14. Baron Von Rotter
    R1100Smee Guest
    WE ARE TALKING VICTORIA
  15. Baron Von Rotter
    R1100Smee Guest
    Coppers will not get you for that the cameras will.
    Coppers apply a different tolerance especially for bikes.
    cameras are not as forgiving.
  16. Baron Von Rotter
    R1100Smee Guest
    Care to back this up with fact?
    All the motorists pinged were paid back.
  17. Baron Von Rotter
    zp Guest
    If you're licence is currently clean, and this being a fairly minor fine,
    then a letter might do it. Two people at work posted letters ADMITTING to
    speeding and apologising, grovelling a bit, never do it again, realise how
    dangerous it can be, etc and both got off. Both had been infringement free
    for 5 years +.
    If that doesn't work then pay up.
    zip
    zp, Jun 18, 2004
  18. Yeah Im willing to lose up to 500 bucks to make a prick of myself over
    this issue. The law is an ass.
    Baron Von Rotter, Jun 18, 2004
  19. Baron Von Rotter
    Deevo Guest
    "Stan Gifford - APAC command centre manager"
    Unfortunately that's 10% over, not under reading.
    Deevo
    Geraldton
    Deevo, Jun 18, 2004
  20. Baron Von Rotter
    sharkey Guest
    You could try telling the teacher a dog ate your homework, I bet
    that's never been tried before either.
    Don't bother with the 10% thing, because His Beakitude will just ask
    you "So if you suspected your speedo could be 10% out, why didn't
    you drive at an indicated 55?"
    -----sharks
    sharkey, Jun 18, 2004
