6230 miles
Discussion in 'UK Motorcycles' started by Lozzo, Nov 8, 2009.
  1. Lozzo
    And 8 1/2 months, that's how long it's taken to empty the Scottoiler
    touring resevoir, and I still haven't needed to adjust the chain in all
    that time.
    Scottoilers rock.
    Lozzo, Nov 8, 2009
  2. Lozzo
    rick Guest
    AOL
    5000 miles since June on the Sprint - one partial refill and a very minor
    chain adjustment yesterday.
    rick, Nov 8, 2009
  3. Lozzo
    muddy cat Guest
    I must have mine set too high as I get 300 miles before I need to
    refill. But I have 14K miles on the chain and it still looks new.
    I'll be switching to chainsaw bar oil on the next refill.
    That they do.
    muddy cat, Nov 8, 2009
  4. Lozzo
    ginge Guest
    Wouldn't they work better if they remained still?
    ginge, Nov 8, 2009
  5. Lozzo
    rick Guest
    Sounds way to high to me. Assuming you don't have the touring reservoir
    addition you should be getting something approaching 1000 miles between
    refills. Have you set it to give 1 to 2 drops per minute at tickover?
    rick, Nov 8, 2009
  6. Lozzo
    Bearing in mind your location, you might want to consider an oil with a
    higher viscoscity, unless of course they offer chainsaw oil in different
    grades for when it's scorcio.
    wessie, Nov 8, 2009
  7. Lozzo
    muddy cat Guest
    It's just the scottoiler, no touring thingy. I think so, I guess I
    should go time it again and see what it's really doing.
  8. Lozzo
    muddy cat Guest
    Only one grade as far as I know.
  9. Lozzo
    Cab Guest
    Hmm, I'm considering one atm, as I tend to abuse the chain on my bike.
    It's really a case of the round tuit. I haven't got one.
    Cab, Nov 8, 2009
  10. Lozzo
    rick Guest
    From Wessies post I'm assuming you are in a hotter part of the world than
    dear old Blighty so are you using the red Scottoil?
    rick, Nov 8, 2009
  11. Lozzo
    Ben Guest
    I was wondering that. I've got a Touring Scottoiler fitted to the new
    Bandit, which is now coming up for 2000 miles. The level appears to
    have barely dropped, although I've only got it set on 1 at the moment.
    I guess as the roads get wetter, I'll need to up the rate a little.
    Ben, Nov 8, 2009
  12. Lozzo
    Ben Guest
    I may even fit one to my GSXR when it comes off SORN next year, as I'm
    completely crap at oiling chains.
    Ben, Nov 8, 2009
  13. Lozzo
    'Hog Guest
    I think the wear rate on chains is also related to the offset between
    swinging arm pivot and output shaft. Some are set up to give the chain an
    easy run as the suspension moves and some really lash the thing about.
    'Hog, Nov 8, 2009
  14. Lozzo
    muddy cat Guest
    It's blue. I didn't know there were different colors.
  15. Lozzo
    wessie, Nov 8, 2009
  16. Lozzo
    muddy cat Guest
  17. Lozzo
    Ben Guest
    It's not so much wear that I'm concerned about, it's have some oil on
    the chain at all. I'm not kidding when I say I'm crap at doing them.
    I think I've done the GSXR 3 times since I bought it, and it's now 17
    months old and on 8k miles.
    Ben, Nov 8, 2009
  18. Lozzo
    YTC#1 Guest
    Engine bars and scottoiler, 1st two items fitted to each bike.
    YTC#1, Nov 8, 2009
  19. Lozzo
    doesn't it make a bit of a mess on the XJ900?
    wessie, Nov 8, 2009
  20. Lozzo
    mark Guest
    I need to think up a nice tidy way to route the pipe along my swing arm.
    I like the Lozzoesque 'p' clip method but not sure I want to drill my
    swing arm while I'm still in warranty....
    mark, Nov 8, 2009
