6 gears or 5?
Discussion in 'Australian Motorcycles' started by chuckonetwo, Jul 29, 2004.
  1. chuckonetwo
    chuckonetwo Guest
    Here's my dumb question for the day.
    My K3 SV650 is advertised as being a 6-gear, however I can only count 6 if I
    include neutral.
    However with manual cars the manufacturer doesnt include neutral in their
    gear count.
    I think I must be missing something obvious.
    Sean
  2. chuckonetwo
    Johnnie5 Guest
    maybe its part italian ;)
    yeh 1 gear
    Johnnie5, Jul 29, 2004
  3. chuckonetwo
    Manning Guest
    You're either miscounting, or you've got a bike with a transmission problem.
    The SV650 *definitely* has six gears - one down and five up (not including
    neutral).
    Manning
    Manning, Jul 29, 2004
  4. Maybe he doesnt go down?
    Al
    http://www.users.bigpond.com/pennykid/alan/index.html
    "The highest form of life in the universe is Man and the lowest is a
    man who works for the post office." - Holly
    Alan Pennykid, Jul 29, 2004
  5. chuckonetwo
    RooMeat Guest
    Yeah thats what I was going to say....
    Have you clicked DOWN from neutral to get 1st??? :p
    RooMeat, Jul 29, 2004
  6. chuckonetwo
    chuckonetwo Guest
    strange, so to move forward to the next question, say for example i just
    havnt been able to get it into 6th gear, and ive had the bike for 8500kms,
    will this have done any damage, particularly in terms of no running in for
    6th?
  7. chuckonetwo
    Johnnie5 Guest
    8500 kays and youve never used 6 ?
    maybe they left it out ;)
  8. chuckonetwo
    chuckonetwo Guest
    to answer the previous posts, yes i always start from 1st, then go up
    through neutral to second, but I only get to 5th. The lever wont budge
    further, so I always assumed 6 speed meant 5 + neutral.
    Im obviously wrong and probably an issue with the bike, however if it's pure
    human error could I have done any damage through not using 6th?
  9. chuckonetwo
    Biggus Guest
    He would have a very sad clutch if thats the case!
    Biggus, Jul 29, 2004
  10. chuckonetwo
    RooMeat Guest
    Cant see that it would do to much in the way of damage.
    But I am very surprised that no-one picked it up when you got the 1000 k
    service done..
    You DID get it done yeah?
    I think I would be going straight back to the shop and getting it checked..
  11. chuckonetwo
    smack Guest
    nope
    smack, Jul 29, 2004
  12. chuckonetwo
    chuckonetwo Guest
    it's already been in the shop fo rthe last 3 months for some repairs...
    they're ficking hopeless
    yes i did get the 100k service done
  13. chuckonetwo
    Johnnie5 Guest
    so go elsewhere
  14. chuckonetwo
    Smiley Guest
    are you, when you leave the lights, counting 5 up movements till it stops
    shifting.
    Smiley
    Smiley, Jul 29, 2004
  15. chuckonetwo
    FuTAnT Guest
    The jetting can change the final drive ratio, so I assume it can also change
    the no. of gears. Get it tuned correctly and it should be sorted.
    Cam
    '03 954
    FuTAnT, Jul 29, 2004
  16. chuckonetwo
    sharkey Guest
    Nope. My guess would be that the shift lever is misadjusted, and
    so can't push far enough to shift into 6th. But I have no idea
    what an SV650s shifter looks like, or if there's anything for it
    to foul on. The XLV quite regularly used to lose 1st if the
    lever fouled the bash plate ... to get to 1st, you have to push
    the lever down a tiny bit more than you do to get to 2nd.
    Probably not, it doesn't get a lot of use on modern bikes anyway!
    -----sharks
    sharkey, Jul 29, 2004
  17. chuckonetwo
    Dale Porter Guest
    You're not simply counting how many gear changes you're making are you? There would be 5 of those on
    a six speed box.
    Dale Porter, Jul 29, 2004
  18. I think I must be missing something obvious.
    the error seems to be in the counting
    if you start with first engaged,
    then you have 1-2, 2-3, 3-4, 4-5, 5-6 = 5
    if you start from neutral,
    0-1, 1-2, 2-3, 3-4, 4-5, 5-6, =6
    which is how it should be done...otherwise you will think one gear is
    missing and go about having a panic and posting questions on NG's and stuff
    fulliautomatix, Jul 29, 2004
  19. chuckonetwo
    SmeeR1100s Guest
    if you go down 1 then go 5 up you have hit 6th gear
    are you sure you are counting correctly?
    SmeeR1100s, Jul 30, 2004
  20. chuckonetwo
    Moike Guest
    But then He'd have to split the cases!
    Moike
    Moike, Jul 30, 2004
