550 Nighthawk Engine Tick
Discussion in 'Motorcycle Technical Discussion' started by tetfordmatthew, Jun 9, 2005.
  1. The original thread is located here.
    http://groups.google.ca/group/rec.m...a290d?q=cb550sc&rnum=1&hl=en#f9dc15ca31ea290d
    Ok, it's been awhile but I have finally recieved and installed the new
    lash adjusters. I bled them according to my shop manual and put
    everything back the way it's supposed to be. Wouldn't you know it, the
    tick is still there.
    I have no idea where to go from here. Is it possible that the valves
    are damaged or the clearances are out anyway? I really have no idea
    what the sound could be. If anyone has any ideas on what the problem
    may be they would be greatly appreciated.
    Thanks
    Matt
  2. The tick is really consistent though, I thought that a cam chain or
    chain tensioner problem would be more of a rattle at lower rpms? I
    guess its possible.
    Would wear on the chain have to be visable or would I have to take it
    out to see if its worn and/or damaged?
    Also I guess I would have to tear down the engine engine (ie remove the
    head) to change the cam chain tensioner. I have seen that bit in the
    book but I can't remember right now.
    Thanks
    Matt
