50cc engines and N2O
Discussion in 'UK Motorcycles' started by Simon Atkinson, Feb 28, 2005.
  1. Paging Petel.
  2. Simon Atkinson
    Haaken Hveem Guest
    Does anyone have experience on 50cc engines and DIY Nitrous Oxyde systems?
    Haaken Hveem, Feb 28, 2005
  3. Simon Atkinson
    Petel Guest
    Funnily enough I was talking about NOS with someone today.
    It`s been done on a 50cc twist`n`go scooter bored to 70cc without any
    problems.
    Talk to any of the shops that supply the systems and ask them for a set-up
    kit for a single cylinder.
    Two potential problems with Nos-ing a 50cc (or any small capacity bike) are,
    1: The inlet manifolds are normally rubber, not good for drilling and
    tapping to fit the injector nozzle. You`d need to source or make a metal
    version of the manifold used.
    2:Electrics, not a problem if it`s already 12v but how are you going to
    power the solenoid/fuel enrichment pump if it`s got 6v electrics?
    G`luck anyway.
    Petel
    Buell M2
    C90-ZZR
    Piaggio Sprinter "Red Dwarf"
    Gilera Sprinter "Blue Dwarf"
    Petel, Feb 28, 2005
  4. Simon Atkinson wrote
    Curses, beaten by a slow ****.
    steve auvache, Feb 28, 2005
  5. **** off hippy.
  6. Simon Atkinson
    Haaken Hveem Guest
    well, thake a look at this.....
    http://www.hondaheaven.org/Article115.html
    A Supercharged CD50 Honda....
    I think that a supercharger maybe is easyer to slap on.
    And i do not think it needs to be supplyed with lubricating oil the
    convesional way, since two strokes already have oil mixed in the fuel
    vapor...
  7. Simon Atkinson
    By DIY, do you mean destroy it yourself?
    Muck, Feb 28, 2005
  8. Simon Atkinson
    It's a 4 stroke...
    That looks like an extra air pump off a yank V8 or something. Sort of
    the thing I want to do with my CG125.
    Muck, Feb 28, 2005
  9. Simon Atkinson
    Haaken Hveem Guest
    no , Do It Yourself.........
    Whinging Courier, Feb 28, 2005
  11. Simon Atkinson
    :eek:))
    I wonder what will happen if he gets a spit back through the inlet
    tract... unless he's got a bit of gauze in there to stop that sort of thing.
    Muck, Feb 28, 2005
  12. I'd expect him to singe his pubes.
  13. Simon Atkinson
    :) Heh.. maybe...
    I think that there was a Turbo F1 engine that burned the fuel before it
    entered the combustion chamber, and injected more fuel into the
    combustion chamber too. That was a strange hybrid engine..
    Muck, Feb 28, 2005
  14. Simon Atkinson
    Petel Guest
    Barking mad! I love it. I could do something similar to my C90 but I was
    thinking along the lines of grafting a Turbo off a Renault Master van to it.
    As someone pointed out you might have lube issues with the 4-stroke unless
    you run it on a pre-mix which would be smokey.
    Anyway to take an oil feed from engine to the charger?
    As for fitting Nos the C50`s have a metal manifold, but god knows how your
    inlet tract works as I can`t make it out clearly from the photo`s so where
    you`d fit the injector is up to you.
    Petel
    Buell M2
    C90-ZZR
    Petel, Mar 1, 2005
  15. Simon Atkinson
    Haaken Hveem Guest
    sorry, but the bike is not mine.... i found it on the net...
    Haaken Hveem, Mar 1, 2005
  16. Simon Atkinson
    <snip>
    Hi Haaken, in this group, the usual thing is to post a reply at the
    bottom like this.
    It's not hard to work out what does what on that bike. There's a plenum
    chamber / flame trap, a compressor, and a carb. I didn't notice a pop
    off valve, like the Bugatti supercharged 8s used to have... strange..
    Muck, Mar 1, 2005
