500 Miles
Discussion in 'UK Motorcycles' started by Tosspot, Jun 21, 2006.
  1. Tosspot
    deadmail Guest
    I know two bike MOT stations without rolling roads. Unfortunately I
    chose to use one that did have a rolling road ('cos it was conveniently
    situated)
    Still, disks done and now it's just a dodgy fork seal to think about. I
    *think* a 'strategic cleaning' session before the MOT (shortly
    before...) may get it through.
    deadmail, Jun 26, 2006
  2. Tosspot
    Beav Guest
    With the coming of computer "aided" MOT stations, I can't see those without
    rolling roads being around much longer.
    And at least with a rolling road, you now the brakes are as they should be.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 27, 2006
  3. Where in the Continent? Shirley you can't do that distance in
    the UK -- I've always been told that nowhere is further than 75 miles
    from the sea.
    They don't have the threaded hole for a thumbscrew in the bottom
    of the twistgrip housing any more?
    Dr Ivan D. Reid, Jul 1, 2006
  4. Just a thought, and I haven't harped on about this for a few
    years. You _have_ adjusted your brake and clutch levers so that your
    forearm, hand and fingers are in a straight line when your fingers are
    resting on the levers? I rode Andy the Pugh's R1 on Pahnd Island with a
    scaphoid injury and for some reaon I couldn't adjust the clutch lever low
    enough. It was agony pulling the clutch in. Having your wrists "cocked"
    is a recipe for pain.
  5. Tosspot
    Tosspot Guest
    Frankfurt - Le Havre, 486 miles if you want to be pedantic.
    Dunno, I'll have a peer at it, but current best sggestion seems to be
    Heli bars r equivalent.
    Tosspot, Jul 3, 2006
  6. Tosspot
    Tosspot Guest
    Now that Sir, is an interesting observation. I don't rest my fingers on
    the levers when cruising, but I will check because a) every little helps
    and b) it's free!
  7. Well, it's the angle the wrist is at when operating the levers that's
    critical; having your fingers resting on the lever to check adjustment is a
    very close approximation to operating position but the (ideal) straight line
    forarm-hand-fingers makes any angling easier to detect.
    Dr Ivan D. Reid, Jul 3, 2006
