500 Miles
Discussion in 'UK Motorcycles' started by Tosspot, Jun 21, 2006.
  1. Tosspot
    Tosspot Guest
    In 8 hours on the 'Bird. Now that, imho, is a long stretch. The problem
    is my right wrist.
    So....any suggestions on Throttle Meisters, lubricant, using left hand
    for throttle control, or, more obviously, just changing the bike?
    In all other respects the 'Bird is actually quite good, but still not a
    patch on the Trophy for munching miles.
  2. Tosspot
    Beav Guest
    Cruise controller?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 21, 2006
  3. Tosspot
    zymurgy Guest
    Pansy ;)
    <thud>
    P.
    zymurgy, Jun 21, 2006
  4. Tosspot
    SD Guest
    Heli Bars?
    Not cheap, but I'd have got rid of the 'bird years ago without them.
    | ___ Salad Dodger
    |_\_____/_| ..80264../..21661.../..31308.
    '^' RBR'06 Points: 75 Miles: 317
    SD, Jun 21, 2006
  5. Tosspot
    SD said...
    I have a set of Gilles clip-ons with optional 75mm risers, I might just
    ft them to the Gixer sometime, just to see what they are like.
    Lozzo, Jun 22, 2006
  6. Tosspot
    I see your puny Jap slides and raise you real mens Italian slides (lock
    paddles would be more apposite).
    sweller, Jun 22, 2006
  7. Tosspot
    deadmail Guest
    I raise you with a K100 clutch.
    deadmail, Jun 22, 2006
  8. Tosspot
    Guzzi clutch? Look, face it, my bike is more poorly designed than yours
    so give up now.
  9. Tosspot
    Tosspot Guest
    That's a bloody good thought. Cheers, I shall investigate that one.
    Ooooh, and theres a shop near me as well. Streuth! 200 squids!
    Tosspot, Jun 22, 2006
  10. Tosspot
    Tosspot Guest
    Yep, should have mentioned that in the original post. Now you point it
    out, it is a bit odd. Maybe I'd better stop...oh...never mind...
    No, its fine, cable nice and free and everything. Maybe I'm just
    cackhanded. But I dont get it so much (it still happens a bit) on the
    Trophy, so the aforementioned Heli Bars might be a good idea.
  11. Tosspot
    Beav Guest
    Try the "Raask Jota bars" then. About 60 quid and they have more
    adjustability than any other bars I've seen.
    I've gorrem on me Zed coz I can't move my shoulder.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 22, 2006
  12. Tosspot
    Beav Guest
    I found a link for Jota bars.
    http://www.busters-accessories.co.uk/proddetail.asp?prod=RAAJB
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 22, 2006
  13. Tosspot
    Tosspot Guest
  14. Tosspot
    deadmail Guest
    Hmm. What about the maintance?
    I'm (almost) ashamed to admit my K100 failed an MOT today... failed on
    *3* warped disks...
    Stupidly I knew they were warped but figured "oh they're good enough"...
    the fuckers only had a bloody rolling road in for the brake tests, damn
    it.
    Equally stupidly I've a set of new disks for the front that I've had
    tucked away for 3 years "just in case".
  15. Tosspot
    Macie Guest
    Macie, Jun 23, 2006
  16. Tosspot
    Beav Guest
    Well I got mine because of my knackered shoulder, but three pals have seen
    and two have ridden the Zed since I put 'em on and all of 'em think they're
    an improvement on the standard, plus they can be set higher OR lower than
    the originals and closer or further away from the seat. All with an Alan key
    and 5 minutes playing.
    I thought they'd only be on until I've had the necessary op on my shoulder,
    but now they're on, they're staying on.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 24, 2006
  17. Tosspot
    Beav Guest
    They're mandatory for brake tests as far as I know, so all MOT stations will
    have them.
    But not them.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 25, 2006
  18. Tosspot
    IIRC, if the MOT station has made a change it's required to have a
    rolling road for brake test.
    The 'change' description is the bit I'm not sure of - it was said in
    passing - but I understood it if a new MOT licence was issued the testing
    station must meet certain new requirements. The question is: is it just
    a new licence or is it a change to that licence (say a new tester on the
    books).
    Also, I don't know any station still using the old Salter scale brake
    tester.
    Muck went to Ingrams in Brighton, the same old boy at the same premises
    for donkey's years, did he have a rolling road?
    sweller, Jun 25, 2006
  19. Tosspot
    Pete Fisher Guest
    They are for an MSVA, and the sodding thing broke on the first attempt.
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Jun 25, 2006
  20. Tosspot
    Beav Guest
    I could be wrong then, but all the bike MO stations I know have them and I
    can't see any of 'em spending money when its not a requirement.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 26, 2006
