Discussion in 'UK Motorcycles' started by Lady Nina, Jul 6, 2004.
  1. Lady Nina
    dwb Guest
    Er.. yes they will... I think.
    dwb, Jul 7, 2004
  2. Lady Nina
    Ginge Guest
    OK, they would happen, but at higher speeds. Speeds which I'll probably
    not reach.
    Ginge, Jul 7, 2004
  3. Lady Nina
    porl Guest
    Blade was ok for me, gixxer is giving me a sore wrist which I can't
    understand. Probably go away though.
    porl, Jul 7, 2004
  4. Lady Nina
    dwb Guest
    Possibly, but I would have thought your ZRX, if anything, would have less
    seat bouncing moments due to it's softer suspension - the GSX-R can be
    rather harsh over some road surfaces.
    I also know that my toy GSX-R can be a bit frisky at times (but the steering
    damper does seem to work), so I don't know what the proper ones are like.
    I'll say Flib wibble do at this point.
    dwb, Jul 7, 2004
  5. Lady Nina
    dwb Guest
    Just one?
    dwb, Jul 7, 2004
  6. Lady Nina
    Yes, and ... ?
    Pip, Jul 7, 2004
  7. Lady Nina
    Ginge Guest
    Not properly leant over, more tipping in and changing up at the same
    time.
    Ginge, Jul 7, 2004
  8. Lady Nina
    Ginge Guest
    Softer suspension, but worse damping.
    Ginge, Jul 7, 2004
  9. Lady Nina
    porl Guest
    Yes, the throttle wrist.
    porl, Jul 7, 2004
  10. Lady Nina
    Ginge Guest
    Is yours the grey and black one, with no yellow on it?
    They look lovely.
    Ginge, Jul 7, 2004
  11. Lady Nina
    porl Guest
    Yes, it is.
    porl, Jul 7, 2004
  12. Lady Nina
    Mike Guest
    <fx:Loudhailer>
    PUT THE FEED LINE DOWN AND WALK AWAY
    Mike, Jul 7, 2004
  13. Lady Nina
    dwb Guest
    Holding on too tight? (Note this is not a euphemism, nor a feedline - it's
    a serious comment)
    Otherwise angle of wrist - in theory you're supposed to maintain as straight
    a line as possible between hand and arm.
    dwb, Jul 7, 2004
  14. Lady Nina
    porl Guest
    I've considered that, but not caught myself doing it. I'm putting it down to
    getting used to a slightly different position. We'll see, maybe it will
    criple me, maybe it'll sort itself out. i haven't done more than 140 miles
    in a go yet.
    porl, Jul 7, 2004
  15. Lady Nina
    dwb Guest
    I did 160 yesterday after having not rode the bike in two and a bit weeks.
    Today I have a stiff (but thankfully not dead) lower back and slightly stiff
    wrists. I do find doing longer rides ends up with me not being able to grip
    as well but that usually goes after a 10 minute break.
    So yes, I'm sure you'll get used to it, or die.
    dwb, Jul 7, 2004
  16. Lady Nina
    you lying cun...
    Oh, "miles">
    darsy, Jul 7, 2004
  17. Lady Nina
    [wrist pain]
    I had this on the Fireblade, until I realised that I wasn't so much
    gripping the whole twist grip too tight, but putting too much emphasis
    on resting the palm of my hand/end of my wrist on the bar, taking some
    weight through it - I got myself into the habit of moving my hand
    slight towards me/clockwise around the bar i.e so that the bit of my
    hand parallel to my thumb was on the bar instead, and the pain went
    away.
    darsy, Jul 7, 2004
  18. Lady Nina
    Also consider tha angle of the brake lever. Even when you're not using
    it, this will often define the angle of your wrist with the bars. As
    it happens, the gixxer's fine for me, but I always check and adjust as
    necessary on any bike I'm going to ride for more than a mile or three.
    Ace, Jul 7, 2004
  19. Lady Nina
    Haven't checked this year's colour schemes - is it the same as mine,
    with none of the usual gsxr patterns on it?
    Ace, Jul 7, 2004
  20. Lady Nina
    More to the point - he leant the bike over? Must be improving then.
    Ace, Jul 7, 2004
Similar Threads
Loading...
