42 to 32-tooth sprocket
Discussion in 'Motorbike Technical Discussion' started by Masospaghetti, Mar 10, 2005.
  1. I have a 1982 Yamaha DT80 and it has a 42-tooth sprocket from the
    factory. I'm trying to increase its top speed so I can use it on more
    roads - right now it only can go about 35 mph, 43 mph at redline.
    Would a 32-tooth sprocket sap too much power from this little motor to
    be practical?
  2. Masospaghetti
    Mark Hickey Guest
    It doesn't sound like that little mouse motor would be able to push
    the bike that much faster. You'd be going from 43mph at redline to
    56.4mph. Thing is, it takes just over double the total horsepower to
    go that much faster (I calculated ~2.14x as much).
    Chances are, the motor Yamaha designed around that bike wasn't blessed
    with twice the horsepower it needed to reach top end... I'd wager
    you'd get at best a mph or two out of a sprocket change (and very
    likely, you'd lower the top end).
    Mark "or use a 130 tooth sprocket and set a land speed record" Hickey
    Mark Hickey, Mar 11, 2005
  3. to go that much faster (I calculated ~2.14x as much).
    It's true that it takes 4 times as much power to go twice as fast. But,
    I suspect that the DT-80 was probably geared very low to climb hills
    off road, and that's what limited its top speed...
    65 mph out of a DT-80 is very believable to me, if the bike is running
    on level ground, with no head wind, and the rider lays down on the gas
    tank...
    I had a Honda 50, bored out to 55cc and I had it up to 52 mph, going
    downhill. My buddy had a 60cc Yamaha streetbike, I disremember what it
    was called, (the DT-80 probably shared parts with it) but he rode that
    darned thing all the way from Lancaster, CA to Torrance---and back---in
    one day. He was on the bike from dawn to after dusk...
    My DT-1 250cc single cylinder bike had about 15 to 20 horsepower,
    depending on which magazine tested it, but it would only go 71 mph, due
    to its mild port timing and gearing. I think it should have been able
    to go up to 15% faster, with appropriate re-gearing...
    Typical gear splits at redline in a motorcycle transmission are about
    15%. I think that if the OP geared his Yammie 15% higher with a
    36 tooth rear sprocket, he might be able to cruise at the speeds he
    wanted...
    But he'd have to redline the engine in the next lower gear to keep
    pulling in high gear, and lay down on the gas tank, on level ground, in
    still air, otherwise, he'd never do it...
    krusty kritter, Mar 11, 2005
  4. Hmmm, that doesn't sound very good.
    My dilemma is that the shop i'm ordering from only has the 32-tooth rear
    sprocket or a 14-tooth (+1 tooth) front sprocket. I am worried that
    will not make a big enough effect.
    Masospaghetti, Mar 11, 2005
  5. Also, It is not important for me to rear 56 mph, just to have the bike
    cruise more easily at around 45 mph. Right now, the thing is howling at
    40 mph, and downright _screaming_ at 43.
  6. am worried that will not make a big enough effect.
    Check some of the chain and sprocket manufacturer's websites. I'm sure
    you can get any number of teeth you want on a rear sprocket, as there
    are only a limited number of bolt circle diameters and number of bolts
    in the circle...
    And, so far as worries about harming a small bore short stroke Japanese
    engine are concerned, lots of RPM won't hurt the engine as much as
    failure to keep your air cleaner element clean and oiled If it's a foam
    type) with no leaks around the element...
    If you don't maintain that air filter, a small bore engine will eat up
    the rod bearing...
  7. Masospaghetti
    Mark Hickey Guest
    The question is - does it need to be screaming to make enough
    horsepower to go over 40mph? If there seems to be a reasonable amount
    of throttle response in the high 30's - that is, you crack the
    throttle and something happens - maybe there's enough power at a lower
    RPM to go 40. If you measure your 35-40mph time with an egg timer,
    chances are good the little motor's doing about all it'll do.
    My own "top end story" was an early 70's Kawasaki 125. I had an
    expansion chamber on it and could get 70.0mph out of it laying
    (literally) on the tank (with my feet out behind me). How do any of
    us ever live to adulthood?
    Mark "overworked guardian angel somewhere" Hickey
  8. What teacup sized engine *doesn't* have to "scream" to make power?
    Answer: a 2-stroke. It just *sounds* busy, as it fires twices as often
    as a 4-stroke engine of the same size...
    I remember a discussion I had with a 4-stroke lover back in the days
    when 2-strokes were everywhere and the 4-stroke owners *hated* the
    "ring dings"....
    The guy actually believed that 2-strokes were "all RPM", while
    4-strokes had "low end torque". He didn't believe me when I told him
    that the average Honda 4-stroke was turning twice as fast as the
    average Suzuki or Yamaha to make the same power...
    An acquaintance used to tell me about riding his illegally-small
    Kawasaki 90 on the freeway (during the 55 mpg speed limit era). He said
    that he would be doing 55 mph, and when the CHP looked at him, he would
    accelerate to prove he still had something left...
    Now there's an original bit of instrumentation...
    Were you wearing a bathing suit and bathing cap, like Rolly Free did,
    on his Vincent,going 150 mph on the Bonneville salt flats?
    By wearing a helmet, to avoid head injuries...
