It was somewhere around Barstow, on the edge of the desert, when the Finally, somebody's found a use for offal. -- Dave GS 850 x2 / SE 6a SbS#6 DIAABTCOD#16 APOSTLE#6 FUB#3 FUB KotL OSOS#12? UKRMMA#19 COSOC#10 Get rid of your SOC/SOB here http://www.sparesorrepair.co.uk/
Plugs was all it needed. New set and it started first time. I don't suppose it helped that the old ones seemed to have been set to almost twice the recommended gap...
Well, that wouldn't have helped, but it's still odd that the plugs would appear to have "gone off". Funny things, motorbikes, aren't they.
I'm guessing that the old 'stale fuel in carbs' may have been a contributory factor too. Certainly took a mile or three before it started to accelerate cleanly through the rev range - initially was hestitating at around 6k, refusing to pull past it a couple of times. Once it was cleared out it was running as sweetly as I could ask for. Aye, they are that.
I've had something similar in the past. The foulest tempered and most reluctant machine becomes sweetness and light simply by changing the (newish) plugs. As you say, odd.
It was somewhere around Barstow, on the edge of the desert, when the It's happened to me a couple of times - all four plugs going dud at once. It's a fairly common thing on LPG engines, largely because the plugs tend to get left in for utterly ages and then fail after some ridiculously long time. -- Dave GS 850 x2 / SE 6a SbS#6 DIAABTCOD#16 APOSTLE#6 FUB#3 FUB KotL OSOS#12? UKRMMA#19 COSOC#10
