400-4 starting problems.
Discussion in 'Classic Motorbikes' started by Ace, Apr 27, 2004.
  1. Ace
    Yep.[/QUOTE]
    Ta.
    Ace, Apr 28, 2004
  2. Ace
    On Tue, 27 Apr 2004 17:39:07 +0100,
    See, there's a problem with that. I've always maintained that fuel
    can't 'go off' or become stale, so if I go down this road (which seems
    the logical choice) I'll have to come up with some new way of
    explaining what happens...
    Ace, Apr 28, 2004
  3. Ace
    I've always wondered about that too. Most years my bike has just
    been left in the garage over winter. Not 'laid up' but neglected,
    no TLC. Nothing.
    Come spring, I'll charge the battery up and try running the bike.
    I've generally not had a problem with the bike starting on the
    'old' fuel that could have been in the tank for up to five months.
    Of course, I can only vouch that this seems to work OK for Kawasakis.
    CT, Apr 28, 2004
  4. Ace
    Geoff Berrow Guest
    Well given that petrol, by it's nature, is a volatile chemical, clearly
    some change is possible given the right time and conditions.
    Your problem is likely to be a combination of things.
    Geoff Berrow, Apr 28, 2004
  5. Petrol is a mixtures of a multitude of hydrocarbons, some of which are more
    volatile than others - the more volatile ones, I assume, will slowly
    evporate off and leave the less volatile ones behind.
    Austin Shackles, Apr 28, 2004
  6. Ace
    Paul - xxx Guest
    Ace posted ...
    A volatile liquid, petrol, which royally screws carbs up, probably due to
    evaporation of some of the constituent parts leaving 'debris' behind, can
    easily be simply not volatile enough to start a cold engine after only a few
    months ... depending on conditions.
    I'd also have a look at all the carb rubbers to see that there's no air
    entering. The rubbers can easily split over time ... assuming 400/4's have
    carb rubbers .. both between carbs / engine and carbs / airbox .. ;)
    Paul - xxx, Apr 28, 2004
  7. Ace
    That's the theory, but my sister-in-law, who's an industrial chemist,
    assures me that this is in fact not the case, hence my stance on the
    subject.
    The thory that evaporation in the carbs themselves might have left som
    'junk' behind is much more likely, IMO.
    In any event, I'll test it out when I get a chance (like, two weeks
    time when I get back from Canada) by draining and cleaning out the
    carbs and filling with fresh fuel, then assuming I get it running,
    drain them again, refit the tank of old fuel and trying with that. If
    (after leaving it for a day to ccol down, obviously) it starts on the
    new fuel but not the old then I'll have to admit defeat.
    I'll let y'all know either way.
    Ace, Apr 28, 2004
  8. Petrol deteriorates it leaves an awful smelling gum behind I have had the
    prob a few times when fuel has been left in a stored biked fuel system.
    erasms
    Erasmus Dim Quebec, Apr 28, 2004
  9. "> >Petrol is a mixtures of a multitude of hydrocarbons, some of which are
    more
    Experience tells me your sister, chemist or no is incorrect it does
    evaporate and leave a gummy substance behind this is after quite a long
    time.
    erasnotachemistims
  10. Ace
    If it smells like gloss paint it's not good.
    sweller, Apr 28, 2004
  11. Ace
    If you read carefully you'll see that I'm not discounting that. The
    idea that a full tank of petrol will have simply lost its volatility
    is what I maintain can't happen.
    Ace, Apr 28, 2004
  12. Ace wrote
    steve auvache, Apr 28, 2004
  13. Ace
    Ace says...
    Adie's bandit had been sitting for over 6 months with a 3/4 full fuel
    tank. Being a tight bastard, and working to a budget, I dcided to try
    and start it and do whatever checks with the fuel it has. It took some
    getting going because oil had seeped past the rings when the engine was
    sat tipped forward for a week, but it starts and runs now on that same
    fuel.
    My old RD250D was once left for 18 months with fuel in the tank. It
    started second kick and I ran it on that petrol until it needed filling.
    Lozzo, Apr 28, 2004
  14. Ace
    Brian Price Guest
    When I lived in South Africa a lot of the petrol out there was produced from
    coal (SASOIL) and I think had a certain amount of either ethanol or methanol
    added ( I can't remember which) and with certain cars, problems occurred in
    the carbs if the petrol was old. I believe it left a build up of a jelly
    like substance in the carbs. This was in the eighties. The first time I saw
    'Fresh Fuel For Sale' at a garage I laughed.
    Probably doesn't help with starting a 400/4 though, although being in
    different hemisphere the fuel probably spirals down the fuel pipe in the
    other direction :)
    Brian
    Brian Price, Apr 28, 2004
  15. Ace
    Snowy's Z200 had been in the back of her garage for about 18 munce, it
    needed a new battery but the fuel still worked.
    platypus, Apr 28, 2004
  16. Not in a full tank of fuel, no - but the small amount in carbs, a most
    definite yes.
    The Older Gentleman, Apr 28, 2004
  17. You didn't sniff the fuel I drained out of the Z200 carb this weekend.
    It smelled, not of fuel, but varnish.
    The problem has got worse since the introduction of unleaded fuel, which
    has that many more additives. The volatiles evaporate, leaving an unholy
    gunge.
    I agree, three months, six months maybe, is OK - anything more is
    trouble.
  18. "> >
    It tends to gum up jets etc .
    ersm
    Erasmus Dim Quebec, Apr 29, 2004
  19. Yes that's the smell Gloss paint of Varnish.
    ersms
  20. Ace
    Mike Fleming Guest
    My Daytona 900 was OK with 3-year-old fuel. I think it's a load of old
    bollocks.
    Mike Fleming, Apr 29, 2004
