37-tooth Sprocket
Discussion in 'Motorbike Technical Discussion' started by Scope, Aug 28, 2003.
  1. Scope
    Scope Guest
    I have a 2002 Honda Shadow Spirit 750. I believe it came with a 40-tooth
    sprocket. I'd like to change it to a 37-tooth to reduce my highway speed
    RPM.
    Is 37 too low? Has anyone done it before?
    I don't care about losing some power in the low gears after the change.
    TIA
    ..: Scope :.
    Scope, Aug 28, 2003
  2. Scope
    Geribaldy Guest
    You're making about an 8% change to your gearing, which you will notice a
    lot, but should still be rideable.Why not try adding a tooth to the front
    sprocket.Assuming it is about 17 teeth it will have the same effect, reduce
    your chain wear and you won't have to buy a new chain (if yours is a bit
    worn you might not be able to tension it with the smaller rear).
    Geribaldy, Aug 28, 2003
  3. Scope
    Scope Guest
    Thanks guys! Actually, I'll settle for a 39-tooth. It should be the right
    balance.
    Where's a good place to get one on the Web?
    ..: Scope :.
    Scope, Aug 29, 2003
