35mm or 36mm Forks - Marzocchi, Cerani or ?
Discussion in 'UK Motorcycles' started by sweller, Apr 12, 2004.
  1. sweller
    I'm investigating improving the forks on my Guzzi. They're currently the
    original gas strut type.
    Marzocchi used to manufacture a replacement but they are quite rare and
    there are none on flea-bay. I believe they also fitted Laverdas and
    Ducatis.
    Other than that, what other (Italian?) machines had good forks with 35mm
    or 36mm stanchions [1], twin brembo caliper (4 pot or std p8 type), total
    length approx 715mm and travel approx 140mm.
    These may fit the bill ...
    http://www.tower.org/museum/ducati/ducati_1977_900ss.html
    http://www.thecreeper.net/laverda/jotadoc_small.jpg
    .... where would be the best place to start looking? Any suggestions as
    to S?H parts dealers?
    Importantly what are they like? Any good? Technical specs?
    Ceriani forks ... ?
    [1] Currently the yokes are 35mm but could be machined out to 36,
    perhaps 37/38.
  2. sweller
    no brainer.
    Sling it in a skip and buy a nice modern jap bike.
    Oh, but can I still have a go first?
    darsy, Apr 12, 2004
  3. sweller
    tallbloke Guest
    <snip search for holy grail>
    While you find some, fit a pair of fontana dampers, well worth the oney
    copmpared to the standard guzzi struts.
    36mm marzochis can be found occasionally with p8 brackets. Usually off old
    ducatis.
    tallbloke, Apr 12, 2004
  4. sweller wrote
    Why not buy a new yoke that is made proper to fit?
    steve auvache, Apr 12, 2004
  5. sweller
    The Le Mans had 36mm yokes, but no handlebar clamps. Cheaper to machine
    my late T3 type out. Probably.
  6. sweller
    Gyp Guest
    Can you fit cartridge emulators?
    Gyp, Apr 12, 2004
  7. sweller
    What are they?
  8. sweller wrote
    Maybe. It just seems wrong though.
    What happens if you **** it up or don't like it?
  9. sweller
    Gyp Guest
    Check out www.racetech.com. Basically they are kits that replace your
    normal damper rod mechanism with the same sort of gubbins you get in
    cartridge forks.
    You get cartridge fork performance without the expense of changing your
    forks. The only catch is that you have to extract the emulator from
    under the spring to adjust the damping rather than having all the
    convenience of the screws on the outside of the shock body.
    Gyp, Apr 12, 2004
  10. sweller
    I'll get another. They're quite common used and not exactly a consumable.
  11. sweller
    I don't think I can fit them as the Guzzi doesn't have normal damping rod
    innards.
    It has precharged gas struts, similar to the struts found on car boots,
    within the stanchions. For all intents and purposes the oil in the
    sliders is only for lubrication.
    Unfortunately the gas struts are not adjustable and only come in one
    'flavour' [1]. This means there can be no revalving to suit different
    riding styles.
    Hence the reason I'm looking at alternatives.
    [1] Tallbloke has mentioned a different type of gas cartridge which I'm
    investigating. Not having much luck with google though.
  12. sweller
    Gyp Guest
    How quaint.
    Have you considered a set of USD forks from Champ's garage?
    Gyp, Apr 12, 2004
  13. sweller
    tallbloke Guest
    Hmmm, dunno. My mate Dale at basicbikes.com got mine for me. I'll ask him if
    he can get any more.
    tallbloke, Apr 13, 2004
  14. sweller
    Les Goodwin Guest
    the words graanmother and eggs are ringing in my ears but you will
    have tried
    http://www.raceco.com/
    yes I tought you would have.
    Les Goodwin, Apr 13, 2004
  15. sweller
    oooh, I'm going to have to go for a lie down now ...
    Of course, of course ...
    sweller, Apr 13, 2004
