322 miles...
Discussion in 'Classic Motorbikes' started by JackH, Sep 29, 2005.
  1. JackH
    JackH Guest
    ....is what I've just got in from covering, on my 'new' SOB, riding it home
    from the previous owners humble abode.
    F reg XJ600 ("Pre-Derision Model"), in surprisingly good original condition.
    No hiccups at all really, bar when I stopped to fill it up in North London a
    bit earlier, when I started it back up, it appeared to have a sticky
    camchain tensioner than didn't free off the whole section I spent plodding
    across London to the A2 from Mill Hill.
    The other niggles, are the clutch slips a little, if you're a bit hamfisted
    when 'aving it large' through the gears - apparently it has synthetic oil at
    the mo; are these affected in the same way as Hondas seem to be, clutch
    wise, if you use this?
    The cable seems a bit tight too, so that'll be being lubed in the next few
    days.
    And... one fork seal looks like it'll need replacing imminently.
    All in all, it seems like a really good buy, given it has a Motad N-eta full
    system, all the discs look recent, the paint is all original, and in March,
    £380 was spent on it doing things like new chain and sprockets, oh, and
    everything works, even all the ikkle lights in the clocks.
    The price was the initial attraction... but seemingly having now gone and
    got it, it's actually a bloody nice bike to ride that I've been pleasantly
    surprised by. :)
    JackH, Sep 29, 2005
  2. They are nice bikes - quick and surprisingly torquey. How much?
    The Older Gentleman, Sep 30, 2005
  3. JackH
    JackH Guest
    This one feels a bit flat between 5 and 6.5k... not that the Motad would be
    causing that, eh.
    450 of your English pounds.
    Front tyre might need doing soon due to sidewall cracking, but this helps to
    confirm the 33k on the clock is almost certainly genuine.
    Lovely bike to ride, and I reckon it might be quite easy to embarass much
    bigger stuff through some of my favourite twisties on it.
    Hell, it even has a really good headlight, something which makes you wonder
    what they were thinking when they then several years later, brought out the
    Fazer.
    JackH, Sep 30, 2005
  4. JackH
    gazzafield Guest
    I've got one with 44,000 miles on it. Good nick and runs like clockwork.
    I use fully synth and have no problems at all with clutch slip.
    I have been very pleased with mine. It takes off nicely at 7k. ;-) Just
    check what kind of regulator/rectifier is fitted. If you have a finned
    type you'll probably be fine. If it's a small flat box I would think
    about changing it. It's the only fault I have had and since sorting it,
    it has been totally trouble free.
    Enjoy.
    gazzafield, Sep 30, 2005
  5. Bleedin' bargain. Even cheaper than my GPz550.
  6. JackH
    The Older Gentleman says...
    Out-TOG'd
    Lozzo, Sep 30, 2005
