30 years today.
Discussion in 'UK Motorcycles' started by Pete Fisher, Mar 15, 2011.
  1. Pete Fisher
    Pete Fisher Guest
    Well not really, but close. The Morini is 31 years old and I acquired it
    29 years ago, so it sort of averages out. All-spares had 6203 wheel
    bearings in stock, so despite being pikey Koyo ones I picked some up
    first thing and whacked them in this morning so that I could get an MoT
    partial re-test for no fee before lunch time. Then off to the post
    office for the first tax disc it's had for 5 years.
    An enjoyable run to the Greasy Spoon for a black pudding and mushroom
    sarnie lunch reminded me of just how good Morini handling is. Stiff as a
    board but pin sharp. Whatever foam R.K. Leighton use to rebuild dual
    seats it's better than Morini's choice, or perhaps 30 years of being sat
    on and several periods of being soaking wet via leaking seams may have
    compromised its integrity.
    Going very well except for the expected mid-range flat spot and
    reluctance to take full throttle under heavy load. I haven't re-jetted
    to suit the pod filters yet (was running open in hill climb trim) and
    they are always a bit tricky to get right with a 2:1 system combined
    with an L5 cam. A tad loud it has to be said - must get some ear plugs.
    Only marred by forgetting to tighten the screws on the cheap chinese
    mirror heads before setting out so that once out in NSL territory they
    turned on their stalks with the wind. Also, I discovered when gettying
    the bike out of the garage that the lever had fallen off on petrol tap.
    Thought nothing of it until on the way home when I really gave it the
    beans down a long straight. It started coughing and banging and refused
    to take more than a whiff of throttle. Stopped in a lay by and it seemed
    to recover so I set off again only for the behaviour to be repeated
    after a few miles. Eased off and it came back on song. Classic fuel
    starvation symptoms. On arriving home I could see that the clear in-line
    filter for the one fuel line was empty. Twit! Using pliers to twiddle
    the tap without a lever I had managed to leave the one side off. 250
    taps are weedy little things and with only one on both carbs are
    fighting for juice via the link pipe. Not an issue on the hill climber
    which had only one bigger bore 350 tap and naturally didn't get held WFO
    for half a mile.
    I love this bike. Difficult to put in to words and incomprehensible to
    most on here I suspect, but my I've missed it.
    | Pete Fisher at Home: |
  2. Pete Fisher
    You could be right, but not all. I feel the same about the Fantic, &
    I've only owned that around 25 years. Funny how they're both Italian...
    Krusty, Mar 15, 2011
  3. Pete Fisher
    Simon Wilson Guest
    +1 Beeza A7
    Simon Wilson, Mar 15, 2011
  4. Ahem.
    Working in a ball-bearing plant opened my eyes a bit to bb quality.
    Koyo were exacting in their tolerances, unlike SKF, RHP and others.
    Grimly Curmudgeon, Mar 15, 2011
  5. Pete Fisher
    Pete Fisher Guest
    In communiqué <>, Grimly
    That's OK then.
    <Googles>
    Oops, making assumptions that as All-spares sell some dubious
    far-eastern excluding Japan bikes they might skimp on their generic
    parts buying. I actually ride past the Timken site (formerly FBC) to get
    to their shop.
  6. Pete Fisher
    NTN were the longest lasting bearings in my scooter. Aren't SKF an
    Australian company, cbf to look it up.
    Muck, Mar 15, 2011
  7. Heh. Time for a combined ages of owner and all bikes, I think....
    52 plus 13 plus 2 plus 18 plus 20 plus 30 plu 30 plus 34
    Equals 199.
    Oh, your comfrey arrived today and The Doctor is delighted.
    The Older Gentleman, Mar 15, 2011
  8. Pete Fisher
    should've gone for Kylie pants instead of the cheapo ones from the NHS.
    wessie, Mar 15, 2011
  9. snot fucking fair.
    Can we do one about the number of bikes in boxes in the kitchen.
    steve auvache, Mar 15, 2011
  10. Pete Fisher
    Pete Fisher Guest
    I wondered how long it would take and who would be first to spot the
    feed line.
  11. Pete Fisher
    Pete Fisher Guest
    In communiqué <1jy6qbr.ouxxak1ak7z7kN%>,
    Hmm, I would have done better at that before I swapped the Voxan for the
    Shiver. How about term of ownership rather than just age of bikes ?
    So, 63 plus 0.5, plus 5, plus 5, plus 13, plus 29 = 52.5, or by your
    rules 63 plus 1, plus 15, plus 18, plus 18, plus 29 = 144.
    Some way to go to beat Ossie Neal's combined age of rider and machine at
    a speed hill climb. Still competing at 80 something on a 1920 something
    Scott outfit.
    Excellent. It doesn't seem to spread as quickly as horseradish, but ours
    became pretty rampant last year. The bees do seem to like it and the
    leaves make good compost apparently.
  12. Pete Fisher
    it's my community caring duty...
  13. Pete Fisher
    Gyp Guest
    +1 R80RT. I rarely use it but when I do it's a bit like getting back
    into my own bed after a month away
    Gyp, Mar 15, 2011
  14. Pete Fisher
    Gyp Guest
    45 (me) + 1 (Tigger) + 30 (R65RS) + 22 (R80RT) = 98
    I could add in 37 if I knew where on earth my Peugeot step through was
    Gyp, Mar 15, 2011
  15. Pete Fisher
    I can understand that, I like getting into your bed when you're away
    for a month too.
  16. Pete Fisher
    Mups Guest
    Steph has owned her CM125 for 25 years but its spend 20+years in boxes
    in various garages around the country. Does that count?
    Mups, Mar 15, 2011
  17. Pete Fisher
    Gyp Guest
    I was going to use a slippers analogy rather than a bed analogy, but
    that would have just made it worse
    Gyp, Mar 15, 2011
  18. Pete Fisher
    Mups Guest
    48 me + 29 (RS200) + 20 (CBR1000) + 15 (YZF750) = 112. Nobbut a child...
    Mups, Mar 15, 2011
  19. Pete Fisher
    39 + 14 (Fully Fared Honda) + 12 (Twist and go 'ped') = a sprightly 65
    Muck, Mar 15, 2011
  20. We knocked out the balls for a lot of bearing makers - most of the
    well-known names. Now, most of them weren't shit, far from it, but Koyo
    insisted on the very best quality all the bleedin' time and a right pita
    it could be sometimes. RHP were the slackest, which wasn't a surprise,
    as many Renault gearboxes were notorious for rough and early bearing
    failures at the time - guess what they were fitted with.
