2011 MOT Changes
Discussion in 'UK Motorcycles' started by Malc, Nov 10, 2010.
  1. Malc
    Malc Guest
    Malc, Nov 10, 2010
  2. Malc
    TOG@Toil Guest
    All seems to relate to cars.
    TOG@Toil, Nov 10, 2010
  3. Malc
    Steve Guest
    Its been doing the rounds on various forums.
    General consensus is that its bollocks.
    Steve, Nov 10, 2010
  4. Malc
    Adrian Guest
    As with all the best scarey-hype stories, there's a modicum of basis in
    reality.
    Pages 8 & 9 of http://www.dft.gov.uk/vosa/repository/MoT - Issue 48%
    20-%20Oct%202010.pdf
    But, really, it's just the MOT starting to enforce a couple of things
    that are already C&U requirements. Yes, it probably does mean the end of
    aftermarket HIDs. <shrug> They're already illegal. Always have been. This
    is not news. They're just generally ignored at the moment. Not exactly a
    surprise that this is being cracked down on.
    But most fuss is being made about remaps - which definitely isn't
    supported there. The sole mention (which basically says "But that's going
    to need a lot more work before it can actually happen") actively refers
    to "illegal" remaps. I'd presume that only refers (in an EU-wide context)
    to non-TuV approved in countries that require TuV approval, and to
    breaches in existing emissions/noise regs.
    Adrian, Nov 10, 2010
  5. Malc
    SIRPip Guest
    That's very interesting, as it happens. Going via the link to the
    advice to testers, it seems a lot is changing.
    SIRPip, Nov 10, 2010
  6. Malc
    "Chipped ECU's - Unsure of just how/if this one will realistically be
    enforced, but any cars with chipped ECU's will in theory be an MOT failure.
    I can only assume VOSA have found an easy way of checking ECU software
    through the cars OBD port (diagnostic plug)"
    Utter *Utter* fucking cunts. Get *out* of my fucking life you cunts.
    Hog, Nov 10, 2010
  7. Malc
    <shrug> Dual-boot ECU?
    platypus, Nov 10, 2010
  8. Malc
    ...they will find the chipped cars as they will probably fail the
    emissions test
    sweller, Nov 10, 2010
  9. Malc
    That isn't always the case and not with bikes either
    Hog, Nov 10, 2010
  10. Malc
    that might work for something made in the last century. Most ECUs made in
    the last decade will use flash memory rather than (E)PROMs. Flipping maps
    would be a simple process for someone with the right cable & suitably
    equipped laptop. If, like the R & K series of BMW bikes, there is a demand,
    someone will knock up a cheap gadget that can be used by the hobbyist.
    wessie, Nov 10, 2010
  11. Malc
    Malc Guest
    Well if it doesn't fail and if they don't use a code reader you'll be
    ok.
    Malc, Nov 10, 2010
  12. Malc
    SteveH Guest
    The only one that could be a worry for many is the airbag warning light.
    That could instantly consign many older cars to scrap.
    Could be a PITA for me, as our 156 has had the light illuminated since I
    bought it - and it won't reset.
    Suppose I could just wire it in parallel with another time delayed
    warning light.... or just get my act together to replace the airbag ECU
    with a working used example.
    HIDs aren't an issue, as it's a trivial job to switch back to standard
    lights for the test and back again afterwards.
    Even the 'chipped ECU' fail doesn't worry me, as the only car I have
    that's chipped is the Cinquecento track car, for which I have a spare
    OEM ECU, which takes a couple of minutes to swap over.
    SteveH, Nov 10, 2010
  13. Malc
    Jim Guest
    We just paid a stupid amount of money to have the airbag ECU replaced on
    our Audi. It wouldn't have been so bad except the controller itself costs
    £700 from Audi, and it takes about 2 hours to dismantle enough of the car
    to remove it.
    You're going to say, I could get a second hand one or get it repaired but
    if it's that expensive to get to I want a brand new one in there thanks.
    Jim, Nov 10, 2010
  14. Malc
    My 944 was chipped, but it still passed the tough NI MOT. It wouldn't be
    hard to identify at an MOT either.
    Hog, Nov 10, 2010
  15. Malc
    I think Steve already identified the "proper" repair.
    Hog, Nov 10, 2010
  16. Malc
    Ben Guest
    http://www.mybluefin.co.uk/
    Ben, Nov 10, 2010
  17. Malc
    no good for the C2 VTS - although they offer a 6 (yes, six) bhp increase
    for £239 by installing a Superchip[1]
    [1] something of a misnomer
  18. Malc
    Hog, Nov 10, 2010
  19. Malc
    SIRPip Guest
    The last five test certs for the Vectra note the presence of the
    illuminated 'airbag' warning light. I think it is down to a 'fired'
    seatbelt pre-tensioner rather than a screwed ECU, but may well be "Game
    Over" when it fails on it.
    I think your first solution is the elegant one.
  20. Malc
    SteveH Guest
    Seems rather optimistic for a chipped N/A engine.
    The only reason I have a chip is that it cost me a fiver on ebay,
    including delivery, and that it smooths out a slight dip in power which
    is engineered into the OEM ECU in order to pass noise and emissions
    tests.
