2 superficial questions
Discussion in 'Classic Motorbikes' started by Ant - 441cc, Feb 7, 2006.
  1. Ant - 441cc
    Ant - 441cc Guest
    It's time to start the engine rebuild on the B44 and superficial issues
    will be the first things to be dealt with.
    The first of these is that I have 1 slightly bent cylinder barrel fin.
    How di i go about fixing that?
    The second is getting the cases nice n clean. Should I do it myself -
    if so, what methods have people found good for getting dirty old cases
    clean and ready for polishing? If not doing it myself, is there a blast
    cleaning method that's suitable? I'm happy doing the final mopping of
    cases, but its the shifting of grime on the non-shiny inner cases,
    rocker cover and cyl barrel that I'm wondering about.
    Ants
  2. Ant - 441cc
    TOG Guest
    In the dishwasher, with ordinary dishwasher detergent. Seriously.
    And now, the voice of experience:
    1. Do not do this when there is any chance of the SO discovering what
    you're doing.
    2. Get rid of as much oil residue as possible first. This is because it
    "mayonnaises" with the water and detergent and coats the inside of the
    dishwasher with said mayo. This may lead to (1) above.
    3. Do not put engine bits in with the crockery. This is because the
    mayo (see 2 above) will coat all the plates and glasses and lead to (1).
    TOG, Feb 7, 2006
  3. Ant - 441cc
    Buzby Guest
    Same mighty bollocking applies when caught using the oven - only replace
    mayo with soot
    Buzby, Feb 7, 2006
  4. TAAAW, never try quick-drying home-made touchpaper in your mother's
    microwave...
    Rusty Hinge 2, Feb 7, 2006
  5. great minds...
    Austin Shackles, Feb 7, 2006
  6. Ant - 441cc
    Roger Hunt Guest
    Never let Nitrogen Triiodide dry uncovered, near an open window.
    Roger Hunt, Feb 7, 2006
  7. *Sick* minds.
    The Older Gentleman, Feb 7, 2006
  8. True, a total waste.
    When I was at school I let some dry on the headmaster's study's doorhandle.
  9. Ant - 441cc
    Roger Hunt Guest
    Was his name Mr Hamza, by any chance?
    Roger Hunt, Feb 8, 2006
  10. Ant - 441cc
    Oily Guest
    Sounds interesting, what is it and what does it do?
    Martin
    Oily, Feb 8, 2006
  11. Ant - 441cc
    platypus, Feb 8, 2006
  12. Ant - 441cc
    Pete M Guest
    Pete M, Feb 8, 2006
  13. Ant - 441cc
    Ken Guest
    You can easily repair bent fins, by applying soap and heating with
    good sized industrial propane torch till soap goes black, then
    carefully and slowing tapping back into line with a strip of hardwood,
    and a copper/hide hammer. Dont let the fin get cold and keep trying to
    move it................it will snap deffo!
    Degrease cases with TFR and steam cleaning, then get them vapour
    blasted, or bead blasted with fine glass bead. Its crucial that all
    blast media is cleaned out of the cases when the job is done though.
    Finally I would be cautious in rebuilding a 441 motor, if you have no
    specific experience with Brit engines, as they can be pretty fiddly and
    if its not done 100% right, then you can end up with major problems.
    k
    Ken, Feb 8, 2006
  14. Ant - 441cc
    Ant - 441cc Guest
    Phew, thanks for that advice. I was thinking of throwing caution to the
    wind and not really doing it 100% right.
    Ant
    Ant - 441cc, Feb 8, 2006
  15. I think he was called Kamal Moustafa Kamal before he was hooked.
    Rusty Hinge 2, Feb 8, 2006
  16. The message <dsbf37$3i7$-infra.bt.com>
    /NI3/
    It's a very unstable chocolate-coloured solid compound made by adding
    iodine to a solution of ammonia.
    When dry, it will be detonated if a fly walks on it, or just by the
    friction of air passing over it.
    Relatively harmless, even in fairly large dollops, we used to filter out
    the precipitate and while it was still wet, smear it on radiators or on
    the floor, or other places. Once, I dotted it over the dining hall walls
    (well away from my table) and the continual <CRACK!> sounds drove poor
    old Charlie [1] bonkers.
    [1] Member of staff who presided over boys' lunchtime sitting.
  17. Ant - 441cc
    Ken Guest
    Sorry thought from your OP questions that you hadnt rebuilt 441 motors
    before...............I stand corrected!
    k
    Ken, Feb 8, 2006
  18. Ant - 441cc
    Ken Guest
    Looking at the pic of your T100 (?), it looks like you need all the
    advice you can get! It is fitted with silencers that are far too short,
    and also looks like the motor is a bitsa, and not the right one for the
    bike.
    k
    Ken, Feb 8, 2006
  19. Ant - 441cc
    Howard Guest
    Erm , in what sort of proportions would add these two ingredients?
    Just curious like.
    Howard, Feb 8, 2006
  20. Ant - 441cc
    Ant - 441cc Guest
    I haven't rebuilt a 441 before but it was just that your advice was a
    bit general. I've owned around a dozen Brit bikes in my time and am an
    ex-toolmaker. Any particular bits to watch out for in your experience?
    Ant
