2-stroke MZ-250 piston reverse-assembled, 4 yrs running !
Discussion in 'UK Motorcycles' started by not@top-post, Aug 7, 2004.
  1. not@top-post
    not@top-post Guest
    Can you believe this ?!
    4 years ago I bought a MZ 250 single 2-stroke of 1975, which judging
    from the original tyres and rust in the tank, had just been parked for
    a few decades. I've used it only for 100km per month since then.
    And it never ran as smoothly [especially not idling] as I've seen these
    east German bikes do.
    Recently the engine sounded noisy, so I suspected the small-end
    bearing. From the book: I confirmed that I could get a 18*22*24
    needle-roller cage before I removed the head.
    The 'new' bearing seems no better than the original communist
    manufactured one, and the big-end seems also not perfect.
    Since the small-end doesn't even rotate - it just rocks back and
    forth - I can't see why it needs needle rollers. The force from each
    explosion would perhaps be better handled by a brass bush - or a
    spring !?
    Strange marks on the cylinder wall and a 'tapering' below the one
    port lead me to investigate and find that the piston had been installed
    REVERSED [back to front] !! I.e the ring gap coincided with port.
    I intended to just reverse the piston and rplace the original needle-cage,
    because the 'new' one', has single needles over the full length [24 mm]
    instead of two sets, offset, like the original.
    Obviously the ring which 'shaved the taper' below the port must be
    worn; although I can't see anything.
    I guess no parts are available, since the factory closed when the
    Berlin wall fell ?
    Have any other readers had experiences with MZs ?
    Comments and advice are welcome.
    == Chris Glur. easlab @ absamail . co . za
  2. not@top-post
    Parts are pretty plentiful - cycle parts for the early ES models maybe a
    bit tricky. Still as cheap too.
    Try BSA-Regal
    http://www.bsa-regal.co.uk/
    Burwins
    http://www.burwin.co.uk/
    and the Daddy of them all:
    Fred Rogers (may not be open as he's recovering from a serious illness)
    01606 593638
    sweller, Aug 7, 2004
  3. not@top-post
    TomTheKraut Guest
    not@top-post wrote:
    [snip]
    Check http://www.mzridersclub.co.uk and contact them.
    Very helpful lads, they are...
    Tom :{)
    BOTAFOT#105 COFF#02/ OSOS#15 KwaSoH#2
    SR500(.de), SRX-4(.jp)
    Make it idiot-proof and someone invents a better idiot...
    Hiroshima pics: http://makeashorterlink.com/?C12E12B97
    TomTheKraut, Aug 8, 2004
  4. not@top-post
    Brian Guest
    Had an interesting reverse issue on an MZ 175 back in the 80's. I was
    going along the A13 London bound on the (?Bow floyover?, the one where
    Newham meets Tower Hamlets) at about 8.30 in the morning and trying
    rather timidly to filter though some tightly packed traffic. Snatched
    the clutch but managed to keep it going OK, or so I thought. Cos when
    there was space I let the clutch out, a lot more carefully this time,
    and discovered that I now had a reverse gear, indeed 4 reverse gears.
    Scared me shitless and created much alarm in others. Lots of hooting,
    as in horns from the cages and wagons, and laughter from the bikes
    ensued. Still it got me there and back.
    Brian
    Brian, Aug 8, 2004
