16-volt CB125RS
Discussion in 'Classic Motorbikes' started by The Older Gentleman, Dec 7, 2008.
  1. The Older Gentleman
    Guest Guest
    [immediately files under 'Way Too Much Information']
    Guest, Dec 10, 2008
    #41
  2. The Older Gentleman
    Rusty_Hinge Guest
    The message <1irr3w5.12n5ail3jeocyN%>
    from (The Older Gentleman) contains these
    words:
    Cover blown!
    YAACustoms Ossifer &ICM£5
    Rusty_Hinge, Dec 10, 2008
    #42
  3. The Older Gentleman
    A.Clews Guest
    Thus spake () unto the assembled multitudes:
    Ha! Don't I know it. My first, er, 'real' bike was an ex-police Ariel
    Leader. It had an anti-theft device (of sorts): basically a switch under
    the seat which allowed current to go directly to the lights so that they'd
    all go pop when they were switched on. After a few sets of lamps blown as
    a result of forgetting I'd armed the switch, I gave up using it...
    A.Clews, Dec 11, 2008
    #43
  4. Strictly speaking, dissipate the excess energy as heat. The
    finned Zener diodes on old British iron did exactly the same thing. A
    switched regulator, as on most modern PC power supplies for example, has a
    higher efficiency because it varies the ratio of time that input gets
    switched to output (wasting little energy as they are essentially in
    either an on or an off state), compared to older analogue regulators which
    have to dissipate the energy not passed to the output within themselves.
    Dr Ivan D. Reid, Dec 12, 2008
    #44
  5. I had a GS550B -- the first model sold in Oz -- and never had any
    electrics problems with it, even after slotting a Cibie' H55 insert into
    the headlight shell. Well, both beams gave up in quick succession in the
    middle of the Hay Plains one Easter Thursday night on the way to the
    Bathurst races, but luckily I was only a few miles from a servo (they are
    _rare_ out there) and I slotted in a Holden sealed-beam unit as a get-me-
    there measure. I did once have a dodgy H55 bulb, with a loose end to the
    high-beam filament -- switching to low beam, the filament cooled down and
    one end pulled away from the support; switching back to high beam gave
    nothing, until vibration touched the end of the filament to the support and
    the resulting arc temporarily spot-welded the contact again[1]. Not so good
    on smooth twisty roads with lots of oncoming traffic... (It could take
    several seconds for high beam to "wake up"!)
    [1] Or maybe the heated filament twisted enough to maintain contact.
    #45
  6. The Older Gentleman
    Mark Guest
    Nether are really true
    All of the older Jap regulators use the equivalent of a pass transistor
    output.
    So the more current you are drawing i.e. headlamp on, the hotter it gets.
    The opposite of the above, is how a Zener regulator works on a motorbike.
    Mark, Dec 12, 2008
    #46
  7. at least some I've seen have a sod-off resistor which is in circuit when the
    headlamp is off.
    Austin Shackles, Dec 13, 2008
    #47
  8. The Older Gentleman
    Err, Ivan's description is accurate, but as you say, it also depends
    on whether it's a series or shunt regulator. I've not encountered a
    switching regulator on a bike yet...
    Yep - Early small Yams certainly did. They relied on the battery to
    provide some additional regulation for the DC side.
    Pip Luscher, Dec 13, 2008
    #48
  9. "Is there a market?" he wonders...
    Dr Ivan D. Reid, Dec 14, 2008
    #49
  10. You are so right. Electrex's wiring diagram, bears no relationship to
    reality at all.
    "It'll have two wires from the alternator. Maybe three, and if three,
    the third will be the earth," they said.
    Their diagram shows a pink wire and a yellow wire coming from the
    alternator. In fact, there are four sodding wires coming from it and
    neither Timo nor I could fathom how to plumb the thing in.
    We searched online for a wiring diagram for a CB125RS. We couldn't find
    one anywhere. Seriously. There does not appear to be one in cyberspace.
    So we tried the 'bodge option'. As main beam (35w) didn't seem prone to
    blowing, but only dip beam (25w), I stuck in a 35/35w halogen bulb.
    Sorted. GEFE[1].
    I shall be on the phone to Electrex tomorrow, suggesting they've made a
    boo-boo and sent me the wrong wiring instructions.
    At least it's now running sweetly.
    [1] Good Enough For Ebay[2]
    [2] Where it now resides.
    The Older Gentleman, Dec 14, 2008
    #50
  11. The Older Gentleman
    Weeell, maybe a lighter, more compact regulator?
    Pip Luscher, Dec 14, 2008
    #51
  12. The Older Gentleman
    Yo're right: I was thinking mains PSUs.
    I *have* heard stories of them (linears) failing through overheating,
    but my (admittedly well-placed) Guzzi one doesn't get significantly
    warm; I've checked.
    I've seen a reg fail due to corrosion when water got in after the
    potting compound shrank and cracked on one unit. I have also had an
    FZR one fail, but that was definitely an intermittent: the lights
    would toggle between bleeding marvelous and adequate. Guess which was
    the fault state! I imagine that failure was vibration induced.
    #52
  13. If it's really direct AC lighting, it does need equal-sized elements. In
    fact, I don't recall (on 6V stuff, admittedly) the bulbs were either 25/25
    or 35/35, I don't recall a 35/25.
    Sounds like it is: the extra wires from the alternator are a bit of a
    give-away, probably one pair are going to the rectifier and the other pair
    are the AC for the lighting.
    's a pity you're so far away, I could probably fix it.
    Austin Shackles, Dec 15, 2008
    #53
  14. The Older Gentleman
    Mark Guest
    Would one of them be the neutral switch wire
    light/green-red ?
    (Assuming you are looking at the wires within the harness on the outside of
    the casing. )
    are the other three Yellow White and black/white ?
    Mark, Dec 15, 2008
    #54
  15. The Older Gentleman
    Give us some credit here, we twigged that ourselves :).
    Green, White, Yellow and black/white - the latter goes to the ignition
    (coil), White goes into one of the inputs of what we believe to be the
    regulator, yellow disappears into the headlamp and is connected to
    'pink' via the pilot light setting (and pilot light *only*), with pink
    also disappearing into what we believe is the rectifier.
    Green goes directly into the rectifier. The rectifier also has pink as
    mentioned above and green/white, which IIRC is the other input into the
    regulator.
    Timo Geusch, Dec 15, 2008
    #55
  16. The Older Gentleman
    Mark Guest
    Fine, then you won't have any problems sorting the rest of it, which is
    equally easy :)
    Mark, Dec 15, 2008
    #56
  17. The Older Gentleman
    Guest Guest
    <fx: grabs popcorn bag from Austin>
    Guest, Dec 16, 2008
    #57
  18. The Older Gentleman
    TOG@Toil Guest
    Actually, the neutral light doesn't come from the generator, you'll be
    surprised to hear. It's totally separate. There are four wires from
    the genny: yellow, white, black/white and green. There are three wires
    from the rectifier: red, green/white, pink (which is the feed to the
    reg).
    Electrex's wiring schematic says you should have four wires going to
    the four connectors on their unit: yellow, black, pink and red.
    I phoned them yesterday, asked where they'd managed to locate a
    CB125RS wiring diagram (because we couldn't) and got this immortal
    answer: "Oh, well, we couldn't find one either, but we know this unit
    will do the job....."
    So Christ knows what their RR212 unit is actually intended for, but it
    isn't a CB125RS. Anyway, they said to send it back and they'll re-
    credit my CC.
    "If you find a wiring diagram for a CB125RS, let us know..." was their
    parting shot.
    TOG@Toil, Dec 16, 2008
    #58
  19. The Older Gentleman
    Mark Guest
    I didn't say it was, but it IS normally in the wiring harness from the
    generator cover as per comment in brackets above.
    That would seem to be a combined regulator/rectifier so it would involve
    bypassing the original rectifier, not worth bodgering the wiring to achieve
    imho.
    KTM 250 apparently ;(
    Mark, Dec 16, 2008
    #59
  20. Yes. That. Is. What. We. Were. Trying. To. Do.
    Not easy, when the wiring instructions with the unit were utterly
    useless and there's no wiring diagram for the bike.
    The Older Gentleman, Dec 16, 2008
    #60
