16-volt CB125RS
Discussion in 'Classic Motorbikes' started by The Older Gentleman, Dec 7, 2008.
  1. The Older Gentleman
    TOG@Toil Guest
    Heh. £55! But yes, the bike will have to be a keeper, I think. It's in
    absolutely superb nick, and huge fun to ride when going well, but it's
    requiring rather more work than I'd anticipated.....
    TOG@Toil, Dec 8, 2008
  2. ****. me.
    Austin Shackles, Dec 8, 2008
  3. I had a GS550 with a superdream reg/rect box on it, worked fine. Mind, I
    think it had the superdream stator as well. This made the GS550 electrics
    almost reliable.
  4. The Older Gentleman
    Simon Muir Guest
    He couldn't afford to, now.
    Simon Muir, Dec 8, 2008
  5. The Older Gentleman
    TOG@Toil Guest
    'Swot I fort.
  6. The Older Gentleman
    Rusty_Hinge Guest
    The message
    At that price it should sing, dance and do without the generator entirely.
    Rusty_Hinge, Dec 8, 2008
  7. The Older Gentleman
    Rusty_Hinge Guest
    The message <>
    Not while there are still dogs in the street...
  8. it did occur to me later that it was probably a typo.
    However, The whole description sound as a bit odd. What age is the bike?
    I've not come across much with direct headlamp on AC except for very crappy
    mopeds and the like, or very old stuff.
    even the god-awful 6V CB100N had a DC headlamp, although it solved the power
    issues by only using 2 out of 6 alternator coils when the headlamp was off,
    and all 6 when it was on, thereby avoiding the need for a regulator as such
    - it just had a rectifier.
  9. Well, it is old. The older 125 singles were all 6v.
    *Shrug*. Don't ask me. Electrex had to go away and look up the RS's
    details, because they'd never done a unit for one before (it is a rare
    bike) and that's what they told me, so I assume that they know best.
    Direct lighting on a 12v electrical system is definitely a bit bizarre.
    The Older Gentleman, Dec 8, 2008
  10. The Older Gentleman
    Mark Guest
    In that case you could have used a rec/reg from a 91-98 CG125 which also has
    AC to headlamp
    Which I have to say amazed me when I first encountered one but then the
    battery in my watch is almost as big as the one fitted to a CG
    Only £8 on ebay, :(
    Mark, Dec 8, 2008
  11. Is AC to headlamp really that rare? I thought "rev it and watch the
    headlamp get brighter" was a symptom of AC to headlight?
    <ponders CB72 wiring loom>
    <gives up in despair, stupid inscrutable Japs>
    mike. buckley, Dec 8, 2008
  12. The Older Gentleman
    Mark Guest
    Well put it this way, nether mr Lucas or mr Wipac had previously tried that
    particular money saving bodge.
    On the CG its only the headlamp that is AC everything else comes off the
    battery.
    Except the ign, which is also AC from a separate coil.
    Mark, Dec 8, 2008
  13. The Older Gentleman
    No, that's more a symptom of a working charging system :).
    Timo Geusch, Dec 9, 2008
  14. Yes, true.
    The Older Gentleman, Dec 9, 2008
  15. quite common on small 6V systems like mopeds and older 125s etc.
    Mind, the symptoms (blowing headlamp) seem to point to wrong bulb in that
    case - direct lighting systems match the bulb wattage to the charging output
    and use the bulb to control voltage, effectively. More'n 12V on the battery
    side is a separate problem (regulator, as stated) and shouldn't cause the
    headlamp to blow, however running a 25W headlamp in a system meant to use a
    35W one probably will.
    Austin Shackles, Dec 9, 2008
  16. Deffo right headlight bulb here - and the 16v recorded by my mutlimeter
    across the battery terminals does rather suggest a fecked charging
    system.
    The new Electrex unit arrived today. It requires soldering of
    connections and the accurate reading of a wiring diagram. I may be busy
    this weekend.
  17. The Older Gentleman
    <opens popcorn>
    Champ, Dec 10, 2008
  18. Well, Timo has kindly agreed to lend a hand, as he knows more about
    keeping the magic smoke in thn I do.
    Hang about...
    <Slaps forehead>
    That means that he's going to... going to... *touch* the bike. I might
    as well junk it now.
    The Older Gentleman, Dec 10, 2008
  19. <Light dawns>
    Rubber gloves! I have a big box in the garage!
  20. The Older Gentleman
    Pah. Nothing short of a full hazmat suit is likely to stop me!
    <cue evil laughter>
    Timo Geusch, Dec 10, 2008
