16.5" vs. 17" tires
Discussion in 'Motorcycle Racing' started by DPGarza, Feb 12, 2004.
  1. DPGarza
    DPGarza Guest
    Can anyone give a wee synopsis of the development of 16.5" vs. 17"
    tires?
    When did 16.5 start to gain favor and why? Were they tried and
    abandoned in the past?
    Where they a development from GP or Superbike?
    All the remarks about 16.5" tires during the Malaysia tests have got
    me curious.
    TIA.
  2. DPGarza
    Tim Lowe Guest
    A 16.5" tire has the same rolling distance (circumference) as a 17". To
    accomplish this the sidewall of the tire is taller. This causes not only a
    different contact patch on the ground, it affects the suspension at lean
    angle. At full lean the forks are approaching parallel with the road, while
    not terribly useful, the taller sidewall of the 16.5" tire can compensate
    and make the bike more compliant over small bumps in addition to providing a
    larger contact patch while leaned over. The drawbacks being that the bikes
    weren't necessarily designed with the rotational dynamics of a smaller
    diameter wheel and that tire development isn't at the same point as for 17"
    wheels.
    --Tim
    Tim Lowe, Feb 13, 2004
