12mm compression tester adaptor?
Discussion in 'Motorbike Technical Discussion' started by fenning.freeserve.co.uk, Jun 9, 2004.
  1. Hi folks
    Can anyone in the UK help with this one, I bought a compression tester to
    check my bike. With it came the usual 18 and 14mm adaptors, however the
    spark plug has a 12mm thread. I have try about everywhere i can think of to
    get an adaptor this size but have failed. It is becoming a real pain in the
    butt!!
    Ive tried bike shops, engineering shops, car accessory & spare parts
    Any advice would be gratefully received
    many thanks & thanks to all who in the past have offered help with other
    issues.
    Allan
    Edinburgh
  2. fenning.freeserve.co.uk
    Mark Olson Guest
    I've broken the ceramic insulator off a plug before and brazed an
    air fitting to it to supply compressed air to an engine cylinder.
    You might consider bodging up a similar thing, perhaps sacrifice
    the 18mm adaptor (or whichever one you will use least often) as
    one half of a homebrew 12mm plug thread->compression tester adaptor.
    Mark Olson, Jun 9, 2004
  3. Hi Mark ,that's actually not a bad idea, will give that some thought, many
    thanks for that info.
    Cheers
    Allan
  4. fenning.freeserve.co.uk
    Charlie Gary Guest
    I made my own from the 14mm. If you send me yours to take the place of
    mine, plus a little money to pay for postage, and maybe a little to cover
    the time I'll put into making the 14mm you send into another 12mm for me,
    you too can have a 12mm adapter. I'm not the closest alternative, but I do
    have what you're looking for.
    Later,
    Charlie
    Fix the e-mail address and it will get to me
    There are about 100 different sorts of insects in Mexico that some people
    eat on purpose.
    Charlie Gary, Jun 10, 2004
  5. The only compression gauge I've had experience with (automotive)
    didn't even use a threaded coupling -- it had a conical rubber fitting,
    with a tire-type valve-stem in the center. One merely held the gauge
    tightly against the spark-plug opening and used a remote start switch to
    crank the engine a few cycles (the valve kept the highest achieved
    pressure until one pressed the release).
    Dennis Lee Bieber, Jun 10, 2004
  6. fenning.freeserve.co.uk
    Daniel Smart Guest
    Gunson do a 14mm adaptor - the same adaptor is used for their Hi-gauge
    and their colortune. You can get it off their website for £3.95 or
    somewhere like Halfords should either have it or be able to get it.
    http://www.gunson.co.uk/acatalog/Gunson_Catalogue_Exhaust_Gas_Analysers_Mixture_Control_5.html
    -Dan
    Daniel Smart, Jun 25, 2004
  7. fenning.freeserve.co.uk
    sammmm Guest
    take a spark plug and weld/braze a fitting on it.
    good luck, sammmm
    sammmm, Jun 27, 2004
