111dB
Discussion in 'UK Motorcycles' started by Matt Horn, May 14, 2005.
  1. Matt Horn
    Matt Horn Guest
    is 111dB considered a bit loud for a bike exhaust? Is there any set figure
    it should meet?
  2. Matt Horn
    Krusty, May 14, 2005
  3. Matt Horn
    Matt Horn Guest
  4. Matt Horn
    I don't know how they test it for road use. The ACU test for
    competition use is a metre away at 45 degrees & 50% of max RPM iirc,
    although for off-road competitions the RPM depends on the engine
    capacity.
  5. Matt Horn
    That's still too loud, my Bandit says 80 dBA on its exhaust.
    Muck, May 14, 2005
  6. Matt Horn
    Matt Horn Guest
    define too loud. This is an afermarket home brew type thing ;-) It's got
    the BSAU thingy on it though.
  7. Matt Horn
    I'd take the BS thingy off if I were you - at least you won't get done
    for fraud or deception or whatever it is then.
  8. Matt Horn
    I don't think that matters now anyway.. the mot people are supposed to
    listen to it. Granted, something that has 111 db is taking the piss just
    a little.
    Muck, May 14, 2005
  9. Matt Horn
    Matt Horn Guest
    Why would it be fraud or deception? Perhaps I should ask MTC exhausts to
    take it out of their manufacturing process then? That's the aftermarket bit
    as is the link pipe, the middle connector section rusted away so I welded
    the headers direct to the link pipe so that's the home brew bit. No baflles
    removed or anything like that though, I've not played with it apart from
    welding the two pipes directly together.
  10. Matt Horn
    Matt Horn Guest
    111dB is only when you wang open the throttle and hold it on the red line,
    tick over is much much lower.
    The MOT guy said "The exhaust is a touch on the noisey side." Still passed
    it though :)
  11. Matt Horn
    Matt Horn Guest
    Oh my car is the same volume too when you step on the loud pedal, holding it
    at red line its a bit lower, but when you step on the gas it is noiseier to
    start with. That's a fully road legal exhaust system that has no problems
    with anything apart from old people thinking I'm speeding.. Why are cars
    treated so differently to bikes?
  12. Matt Horn
    Holding it the red line, I'd expect the mechanical sound to figure
    heavily in that 111 db reading too.
    Excellent, desired result then. I want a link pipe for my Bandit that
    has a center stand bump stop on it. Then I can keep my center stand, and
    have a nicer pipe.
    Muck, May 14, 2005
  13. Matt Horn
    Dan L Guest
    I had considered getting one for my new [1] Laser K2 system, but at tickover
    it's quite civilised so I don't think I'll bother. Mind you, at full chat
    it's somewhat cacophenous.
    [1] new, as in new to me thanks to Ebay.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, May 14, 2005
  14. Matt Horn
    Matt Horn Guest
    I welded a plate in place on the pipe - should yours not come with one I'd
    be happy to do the same for you.
  15. Matt Horn
    That sounds like a plan to me. I can't have my center stand hitting my
    nice alloy swing arm can i?
    Muck, May 14, 2005
  16. Matt Horn
    Matt Horn Guest
    nope, you canne have that! My came with a sort of plate on but it was the
    wrong size and they'd drilled out a massive great big hole which was too big
    to take the stop from the old one.... so I welded in a nice stainless one
    Welding is so satisfying, although when I did that one I had a short sleeve
    shirt and didnt bother with gloves, I've a nice tan and some slight 'sun'
    burn now :-(
  17. Matt Horn
    Stainless is really nasty stuff to drill. I may have a go at making up a
    stop to go onto the pipe soon, when I get my other projects out of the
    way first.
    Would sun block have helped I wonder?
    Muck, May 14, 2005
  18. Matt Horn
    Matt Horn Guest
    should do I'd have thought.
    Matt Horn, May 15, 2005
  19. Matt Horn
    Ah right, I assumed the "home brew" bit referred to the can. No problem
    then if you haven't modified that.
    Krusty, May 15, 2005
  20. Same thing happened to me recently while doing a couple of hours
    welding. I got a lovely UV burn on my left inner forearm from not
    wearing gauntlets or long-sleeved shirt.
    Lesson learned for next time.
    Grimly Curmudgeon, May 15, 2005
Similar Threads
Loading...
