110v wire welders
Discussion in 'Motorbike Technical Discussion' started by Iowa883, May 1, 2005.
  1. Iowa883
    Iowa883 Guest
    Do any of you have this type of welder in your shop/garage ? What all do you
    weld with it ? Also what type of gas do you use, 75/25 ?
    Thanks,
    Iowa883
  2. Iowa883
    Les Guest
    I have a Lincol WeldPak100. I've used it to weld carbon steel, with 75/25,
    and aluminum and stainless steel using 100% Argon. Aluminum is a bitch to
    get used to, and the lead must be kept as straight as possible. Stainless
    was very easy, ran about the same as carbon.
    I repaired a primary cover for my Triumph with it, as well as frame repairs,
    built a sidecar, oil tank, you name it. As someone else said, you'll have to
    watch the duty cycle, especially welding heavy materials.
    You need to be sure you have a 20 amp circuit to run it on, no extension
    cords, and make sure you have clean materials. Grind the areas to be welded,
    don't just trust a wire brush. Make sure that you have a good ground too, or
    you'll have problems.
    If you start welding anything structural on a bike, make damn sure you can
    trust your life to your welding... You will every time you ride.
    Les
    Les, May 1, 2005
