106 BHP Limit Q
Discussion in 'UK Motorcycles' started by Cab, Jun 22, 2006.
  1. Cab
    Cab Guest
    Anyone know anything about European Law?
    I got this from FEMA, when I questioned the legality of the 106BHP
    limit.
    Concerning the 100bhp limit in france, bikes sold in that country, as
    anywhere else in the EU, are regulated by the legislation on European
    Type approval. At present, there is no proposal related to a speed or
    power limitation for motorcycles. Such proposal (the 100bhp limit) was
    -as you know- on the European agenda about 10 years ago, but FEMA
    stopped it by showing that it was not useful in terms of road safety,
    reffering to a research undertaken by a Dutch research institute (TNO).
    The question of the French situation of limiting the power to 100bhp
    reduces the choice for French riders and could be considered as a
    limitation to the principle of free circulation of goods within the EU.
    In some instances, it could also be a limitation to the free
    circulation of persons, in particular in the case of a European citizen
    transferring his/her residence in France and wishing to register a bike
    that was first registered in another EU country. It is possible for any
    citizen to submit an appeal to the European Commission in order to get
    a reply, in light of the treaties and directives
    So then, if I did buy a bike in the UK and bring it over to France,
    what are my chances of fighting the above and winning? How could I do
    this?
    I need to get in touch with the FFMC (French MAG - Fédération Française
    des Motards en Colère [1][2]) and check this out.
    [1] I just love that name...
    [2] Yes, I am a member.
    Cab, Jun 22, 2006
  2. In uk.rec.motorcycles, Cab belched forth and ejected the following:
    Why fight it?
    It sounds clear to me; the 100bhp limit have never been introduced.
    That's one way of putting it ;-)
    Whinging Courier, Jun 22, 2006
  3. Cab
    Cab Guest
    I assume you meant to put a "should" between limit and have. In proper
    countries, it hasn't.
    :pp
    Cab, Jun 22, 2006
  4. Cab
    WavyDavy Guest
    My take on it has always been that there's no EU-wide power limit, but
    individual states can set any limit they want - EU directives etc tend to
    set the upper limit, so if the EU limit was 106bhp and the UK decided 120bhp
    was OK, then the UK would be in trouble.
    Setting a national limit lower than any EU limit, or setting a limit when
    the EU has not said whether there should be one either way would not, AFAICT
    be contravening EU rules as they don't say member states *can't* set power
    limits....
    But also, AFAICT that only applies to bikes sold in France
    I'd be interested to see how a case went with regard to an EU-homologated
    UK-spec bike being re-registered in France without power capping.
    WavyDavy, Jun 22, 2006
  5. Cab
    Pete Fisher Guest
    I never thought of that. Presumably the equivalent of an MSVA test in
    France includes a dyno test., but then if the bike already has a
    Certificate of Conformity it wouldn't need a test and would be OK as
    long as it showed power within the limit.
    Mad old git that I am I did it the other way round so power was the
    least of my problems.
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Jun 22, 2006
  6. Cab
    Cab Guest
    There is no EU set limit, as the proposal was thrown out years ago.
    Well, I've thought that one of three things could apply:
    1. Freedom of choice
    2. Illegal imposition of 106BHP rule (not sure if this is true)
    3. Free movement of goods (as shown in my OP)
    You couldn't. You'd need to get it restricted and prove it was
    restricted before getting the "certificate des mines" and then being
    able to register it.
    Cab, Jun 22, 2006
  7. Cab
    Cab Guest
    Time is the thing I don't have too much off. This is a problem.
    Money? Well, maybe I can get assistance from other interested parties,
    if I can drum up enough support.
    Cab, Jun 22, 2006
  8. Cab
    Cab Guest
    I'm not sure it'd be dyno'ed or not, but some form of proof would be
    required. The model being sold in the country also helps, as it's a
    nightmare for grey imports that aren't sold in France.
    Heh, quite.
    Cab, Jun 22, 2006
  9. Cab
    Cab Guest
    Then waging war against the EU is not for you.[/QUOTE]
    Heh, I know. I'm trying to assess my options atm.
    Cab, Jun 22, 2006
  10. Cab
    Errrr. Not sure about that. Not done it, but when I paid French duty
    on the gixxer I got all sorts of paperwork and was given to believe
    that I just had to present it to some office in Mulhouse to register
    it. Same with the cars.
    My belief was simply that all the models were standard, so there would
    be no questions asked, no need for any other certification. Certainly
    this is how it worked importing vehicles into Suisse, although I
    accept that it's _possible_ that froggy beaurocracy may be even worse
    than Swiss.
    SWK may be along shortly...
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jun 22, 2006
  11. Cab
    What makes you think this is the case? I recall when dog was trying to
    import one of their bikes he had all sorts of problems and had to get
    aforementioned certificate sorted, but that was for a grey import. Any
    model that's also sold in France shouldn't need any additional
    paperwork. AFAIAA.
    _______
    Ace, Jun 22, 2006
  12. Cab
    Beav Guest
    The word could have been "has" in place of "have"
    In proper
    France isn't a proper country? Don't let the frogs know that.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 22, 2006
  13. Cab
    WavyDavy Guest
    *I_KNOW*.
    There is no EU limit, therefore there is no ruling from the EU, therefore it
    is perfectly possible that separate member states of the EU can set their
    own limits without being in contravention of any EU limits which may (but do
    not) exist.
    That was the point I was making.... That they'd only be in contravention of
    the (non-existent) EU 'limit' if any particular country chose a 'limit' over
    it. If there was a 'limit' then by definition it'd be a 'limit', so member
    states could easily say their limit was lower and not contravene it.
  14. Cab
    *ding*
    That's the one. He had to jump through hoops to get the paperwork
    (presumably this 'certificate des mines' referred to). Took weeks, as
    I recall.
    It's the frog aversion to sports bikes, I think. They'd argue (in
    fact, someone on here tried just that recently on a thread x-posted to
    frm) that trailies and their ilk are much more suited to twisty alpine
    roads. I beg to differ, of course :)
    _______
    Ace, Jun 22, 2006
  15. Cab
    Pete Fisher Guest
    There seems to be no shortage of them round 'our way' - but then it's
    not exactly alpine. Serious enduro country (Gilles Lalay Classique
    territory) so lots of bona fide off-road stuff, but also groups of
    sports bikes blatting up to the big lake and back on a Sunday. We are
    near a junction where they turn off to the right as a hairpin bend. Just
    like a reverse Ramsey hairpin. Sounds almost like 'Pahnd Island'
    sometimes.
  16. Cab
    Cab Guest
    From my post to frm:
    l'article R321-5 précise:
    " Le ministre chargé des transports fixe par arrêté les dispositions
    nécessaires à la vérification de la puissance et de la vitesse maximale
    des motocyclettes, des tricycles et quadricycles à moteur et des
    cyclomoteurs. "
    Cab, Jun 22, 2006
  17. In uk.rec.motorcycles, Beav belched forth and ejected the following:
    Thank you, it was. I *have* cleaned out my blimmin' keyboard now.
    It was dropping "d"s like a bastard until then, too.
    Whinging Courier, Jun 23, 2006
  18. Cab
    Yeah, and? It doesn't say anything about importing from other
    countries.
    _______
    Ace, Jun 23, 2006
  19. Cab
    Cab Guest
    Doesn't the phrase "Vérification de la puissance" give it away?
    Cab, Jun 23, 2006
  20. Cab
    It doesn't say anything about importing from other countries. Without
    this context, it simply says they have the authority to test maximum
    speeds and power outputs. I'd guess that it's much more concerned with
    mopeds, 125s and 33kw limitations than full power stuff.
    _______
    Ace, Jun 23, 2006
