Discussion in 'Motorbike Technical Discussion' started by Nichts, Sep 3, 2009.
  1. Nichts
    Nichts Guest
    So I've had the bike out today for awhile, and after having swapped
    the plugs with fresh ones and carefully tuning the carbs as outlined
    above, it seems to be going along significantly better. The plugs got
    a little fouled (just a dusting...this is quite monumental, though),
    but that's probably because in my eagerness to ride it, I forgot to
    let any excess burn off. I will brush them off again tomorrow, and
    tinker with it a little more. Thanks a lot guys. You'll probably be
    hearing from me again soon. I expect this bike to be fairly high
    maintenance.
    Nichts, Sep 3, 2009
  2. Nichts
    1949 Whizzer Guest
    If you're running the correct heat range spark plugs, the porcelin
    insulator inside won't be tan like it would be if you well using
    leaded gasoline.
    There should be a ring of black soot maybe 1/8th of an inch wide deep
    inside the plug where the insulator and the steel body of the plug
    meet.
    Experienced tuners have a magnifying flashlight to inspect the spark
    plug to see if the ring exists. If there's no soot deep on the
    insulator inside the plug, the mixture is too lean.
    Soot on the exposed end surface of the threaded part of the plug is
    meaningless, as the cylinder head temperature will only reach 350~375
    degrees.
    If you see any brown color on the plug that's oil being burned, unless
    you are using an octane booster for some strange reason.
    1949 Whizzer, Sep 3, 2009
  3. Nichts
    1949 Whizzer Guest
    However, you should realize that the expert tuners are checking the
    plugs after a hard run for several miles and a "clean cut" during
    which the engine is shut off and the clutch pulled in and the
    motorcycle is stopped without the engine ever being allowed to idle
    and cover up the mixture indications with extra soot.
    The CV carburetor used on motorcycles since about 1970 is a mysterious
    device to most tuners who have no idea whatever as to the intention of
    the designer.
    The whole idea of a CV carburetor is to take direct control of the
    midrange and high speed circuits away from the rider. This makes the
    engine run leaner and cleaner most of the time the rider is cruising
    along at small throttle settings.
    And the idle mixture screw works opposite from the air screw that
    older slide valve carbs had.
    Turning the air screw clockwise richened the mixture, turning the idle
    screw clockwise leans the mixture.
    And tuners who are trying to "lean out" the idle mixture wind up
    turning the idle mixture screw counterclockwise too far, so they have
    to turn the idle speed up to compensate for excessively rich idle
    mixture.
    Most amateur tuners don't realize that there is a pattern of three
    acceleration transition ports that are controlled by the lower edge
    of
    the throttle butterflies.
    If a CV carburetor is unresponsive to the idle screws, the first
    thing
    to do is turn the idle speed screws counterclockwise to close off the
    acceleration transition ports.
    If you have a set of CV carbs on the bench and look into the
    downstream side, what you should see is just half of *one* of the
    three transition ports, the other two will be covered up by the
    closed
    butterfly.
    The transition ports are not affected by the adjustment of the idle
    mixture screw at all. They are controlled entirely by the position of
    the butterfly.
    You cannot set the idle mixture if the throttle butterflies are too
    far open because the engine sucks unregulated mixture from the
    transition ports.
    However, if the excessive richness is *not* due to the butterflies
    being too far open, the other possible culprits are stuck float
    valves
    or floats that are adjusted too high, causing too much fuel to
    accumulate in the float bowls.
    When the fuel level is too high, the engine can easily suck too much
    fuel through the idle jet because it takes less engine vacuum to suck
    the fuel up.
Similar Threads
Loading...
