£250 job done ;)
Discussion in 'UK Motorcycles' started by Nige, Mar 28, 2009.
  1. Nige
    Nige Guest
    Been to the dealers for some parts prices. It needs -
    All four new vales £120
    2 new tensioners & gaskets £80
    Head gasket £20
    I'm gonna do the job myself, I might do all the labour intensive shit like
    taking it to bits & get my spannerman to fettle the valves & the shims etc.
    Have i missed anything out thats obvious to those that know better?
    Nige, Mar 28, 2009
  2. Nige
    crn Guest
    Depends on how hard the valves got whacked.
    It might be wise to change the piston and big end shells.
    How much damage can you see on the top of he piston ?
    Shock loads can do strange damage to almost anything including the gearbox.
    Check for stretch in the primary chain etc.
    crn, Mar 28, 2009
  3. Nige
    Nige Guest
    No, but you can hear it pretty well. I'm not ordering anything until i whip
    the head off, but my mates just had exactly the same thing the day after me
    & thats all his needed.
    We'll see.
    Nige, Mar 28, 2009
  4. Nige
    Nige Guest
    They can only be hit as hard as the laws of physics allow. They can't be hit
    any harder on my bike than my mates bike. He reckons he did the same sort of
    time as me with it clattering, about 20 seconds at the most.
    Nige, Mar 28, 2009
  5. Nige
    Eiron Guest
    Primary chain? Did Honda ever use them?
    Eiron, Mar 28, 2009
  6. Nige
    Beav Guest
    What damaged the valves?
    Did the valves come into an contact with the head at an odd angle?
    Has the piston taken a twatting?
    Piston broke?
    Little end still round with no flat spot?
    Big end still round with no flat spot?
    Crank Ok, not cracked due to explosive detonation of valve heads?
    Cam chains Ok?
    This fucking list could go on and on.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 28, 2009
  7. Nige
    Beav Guest
    And who's to say your mates valves were hit by a piston moving at the same
    speed as yours were hit?
    One engine can dink a valve and simply bend the stem and yet another (same)
    engine can hit a valve, snap the head off and chew the **** to pieces using
    all the nice metally bits inside the engine as teeth. Or to put it another
    way "Physics my arse"
    I'd be interested to know how long your pals engine lasts after it's been
    "rebuilt" if that's the case.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 28, 2009
  8. Any man who utters the words "whip the head off" has my full support because
    there's nothing much better than taking a dead engine to bits and then
    reviving it. Go Nige - if I lived nearer I'd be round with a crate, cheering
    you on!
    Mungo \Two Sheds\ Toadfoot, Mar 28, 2009
  9. Nige
    zymurgy Guest
    Christ, you're grumpy today, and your glass is half empty.
    He might get lucky, if he just does the top end and doesn't inspect
    the bottom.
    But, looking on the bright side, the more new parts he buys for my
    bike, (when he finds it's totally fucked), the better :)
    Carry on Nige ... !
    Paul.
    zymurgy, Mar 28, 2009
  10. Nige
    Nige Guest
    You have transport, get over here, now.
    Nige, Mar 28, 2009
  11. Nige
    Nige Guest
    the bottom.
    Mardy old **** isn't he? :)
    Makle me an offer for the bike as it is, with new tryes, chain etc.
    Carry on Nige ... !
    Paul.
    Nige, Mar 28, 2009
  12. Nige
    If it's anything like my old TL or current Aprilia, both pots will
    have comletely independent valve trains. Well, almost completely in
    the case of the TL. I doubt both would've failed at exactly the same
    instant.
    Pip Luscher, Mar 28, 2009
  13. Nige
    <tries to make sense of post>
    <fails>
    Pip, Mar 28, 2009
  14. Nige
    Nige Guest
    Same here, what was all that about?
    Nige, Mar 28, 2009
  15. <Looks at watch... looks at bike... looks at cider>
    Nah, you're ok, Nige, another time.
  16. Nige
    Jeweller Guest
    Aprilia? Aprilia?
    Perk!
    Jeweller
    R100RT
    Formerly: James Captain, A10, C15, B25, Dnepr M16 solo,
    R80/7, R100RT (green!)
    www.davidhowardjeweller.co.uk
    Jeweller, Mar 28, 2009
  17. Nige
    "both pots"
    wessie, Mar 28, 2009
  18. Oh, foo uck doff.
    Grimly Curmudgeon, Mar 28, 2009
  19. Valve guides, quite possibly. If it's bent the valves, it may have
    damaged the guides. And the piston crown.
    I'd also be very surprised if there aren't a few O-rings or seals to be
    replaced as well.
    The Older Gentleman, Mar 29, 2009
  20. Nige
    Pete Fisher Guest
    When my Husky 510 'dropped a valve' the head of the valve came off and
    damaged the piston and the cylinder liner. They were well known for it
    though and revving the tits off it down to the hollow at Gurston
    courtesy of the lightened flywheel, combined with a worn out cam chain
    and a fluffed gear change was just too much provocation.
    Luckily the head wasn't too badly damaged. As you say, easy enough to
    check. I might be inclined to at least check the cam chain length
    against spec. if that can be obtained. No point putting a clapped out
    chain back on.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 29, 2009
