£1,259.48
Discussion in 'UK Motorcycles' started by antonye, Oct 14, 2006.
  1. antonye
    antonye Guest
    Blimey that service was a bit more than I expected!
    1 x r/h opening rocker @ 77.42 = 77.42
    2 x l/h opening rocker @ 77.42 = 154.84
    2 x 2.90 opening shim @ 2.95 = 5.90
    1 x 2.70 opening shim @ 2.95 = 2.95
    4 x cam carrier shim @ 0.19 = 0.76
    2 x opening cam cover gasket @ 0.93 = 1.86
    2 x closing cam cover gasket @ 0.93 = 1.86
    1 x intake duct gasket @ 0.80 = 0.80
    2 x rocker pin gasket @ 0.77 = 1.54
    1 x oil filter @ 5.01 = 5.01
    1 x sump plug washer @ 0.12 = 0.12
    2 x cam belt @ 28.09 = 57.80
    2 x fork outer tubes* s/h @ 133 = 266
    2 x oil seal @ 7.89 = 15.78
    1 x shell 7.5w fork oil @ 8.51 = 8.51
    1 x fuel pump o-ring @ 4.88 = 4.88
    1 x fuel filter @ 11.63 = 11.63
    3.3 x shell ultra oil @ 7.66 = 25.28
    2 x DCPR9E spark plugs @ 5.96 = 11.92
    2.5 x coolant @ 5.11 = 12.78
    sundries = 4.26
    * should be £626.35 each [1]
    Total = 671.90
    + 10 x hours labour @ £40ph = 400
    Sub Total = 1,071.90
    + VAT @ 17.5% = 187.58
    Grand Total = 1,259.48
    Less Discount of £916.44 = £376.84 to pay :) [2]
    [1] my fork bodies had corroded badly and Mitch had some
    second hand ones in stock which he let me have cheap
    [2] for very large values of :)
  2. How the hell Ducati can charge £80 for a rocker that has the life
    expectancy of a melting chcolate.....
    The Older Gentleman, Oct 14, 2006
  3. antonye
    antonye Guest
    The new ones are ok, the 97-99 ones are where they
    had problems with crap chrome, so they should be
    ok now. Fingers crossed!
  4. antonye
    Donald Guest
    Desmodromic, even the name sounds expensive !
    Paging Donegal Paul, sounds like a job here which pays well !
    Donald, Oct 14, 2006
  5. <VBG>
  6. antonye
    Ken Guest
    What do you expect, if you buy a bike more likely to fall apart than a
    Harley?
    k
    sundries = 4.26
    Total = 671.90
    Ken, Oct 15, 2006
  7. Imo, if Duc produced a shite component they should foot the bill for
    free replacements.
    Grimly Curmudgeon, Oct 15, 2006
  8. antonye
    antonye Guest
    Posting things like that is why everybody can see that
    you know sweet **** all about motorbikes.
    antonye, Oct 16, 2006
  9. antonye
    antonye Guest
    I had to read it twice, but I got there in the end ;-)
